LSD Gear Oil...
you change the oil more frequently than usual, and use the recommended oil from the lsd manufacturer. The procedure is the same as any other tranny fluid change, loosen the 3/8 drive bolt, and carefully catch the fluid. Once done draining, be sure to add a couple ounces of fresh fluid through the fill hole (19 or 17mm cant remember) to flush the left over crap. Then replace the drain bolt, and add the recommended oil until it seeps from fill hole.
matt
matt
