Integra DA (90-93) Mugen Trailing Arm Bushings
Old Nov 10, 2005 | 07:35 AM
jmcclin2's Avatar
Default Integra DA (90-93) Mugen Trailing Arm Bushings
I know there are other posts concerning the 'best' trailing arm bushings - but I could not find a Mugen replacement for the DA - I contacted King Motorsports who sell Mugen bushings and they said that for the 90-93 Integra they make a special sleeve for the existing Civic bushing, which then will fit the Integra trailing arm. The sleeve is put around the Civic bushing and then welded together. The cost for the Integra bushings is $225, while the standard Civic bushings are about $114. I did a DA to EF rear brake swap and the DA bushings where shot to hell - so I did a bit of research. It looks like it will be cheaper to re-use the original EF trailing arms and replace the bushings in them instead of the new DA arms. Mugen's seem like a good comprimise between the OEM and the poly. Anyways, hope this helps someone looking for this info.
JCM
Old Nov 10, 2005 | 07:39 AM
projectTeG's Avatar
i found a post here on H-t about how you can use the mugen TA bushing on the DA trailing arms. ***EDIT*** i found the link i read http://g2ic.com/forums/showthr...shing
Modified by projectTeG at 4:54 PM 11/10/2005
Old Nov 10, 2005 | 08:40 AM
DAmpa-chi's Avatar
Default Re: (projectTeG)
A company called OPM Autosports sells a modified CRX Mugen Bushing that will fit in the DA Rear Trailing Arm. I've got them on my integra and it makes a huge difference over the stock worn ones.
http://www.opmautosports.com/p....html
92civicfreak
Suspension & Brakes
Mar 26, 2008 08:37 AM
Mugen_DC2R
Sep 28, 2006 02:25 PM
importboi22
Suspension & Brakes
11
Feb 28, 2005 12:33 AM
carl_aka_carlos
Dec 16, 2004 02:01 PM
pdiggitydogg
Feb 24, 2004 04:17 PM
