Anyone on here from dallas area that knows anything about GSR dash in a civic?
I will pay or trade some parts for some help. I still need my turn signals and tachometer wired up. In my hatch I will be waiting to hear from someone. I have a gsr guage cluster and other little things. Someone please help.
I already hit MIGS up he is a good friend of mine. He already tried and can't do it. He is sick right now anyway so still no help.
teg's blue left side plug (13 pins)
1.blu-tach signal
2.grn/org-check engine indicator
3.yel/red-oil pressure switch
4.-
5.wht/blu-charge indicator
6.-
7.yel/grn-coolant temp
8.blk-ground
9.red/blu-cruise (if you have cruise)
10.yel-hot
11.-
12.pink-maintenance (not used)
13.-
teg's right side blue plug (16 pins)
1.grn/red-e.brake signal
2.red/grn-high beam
3.grn/yel-right turn
4.grn/blu-left turn
5.-
6.blk/yel-power
7.red/blk-power
8.red-power
9.blu/red-abs (not used)
10.grn-trunk switch
11.org-vehicle speed sensor
12.-
13.blu/wht-low fuel (not used)
14.yel/wht-fuel gauge
15.lt grn/red-door switch (not used)
16.red/blu-seat belt
civic's left side grey plug (12 pins)
1.yel/wht-fuel gauge
2.yel/blu-vehicle speed sensor
4.grn/blu-left turn
5.wht/blu-charge
6.yel/red-oil pressure switch
7.-
8.blu-tach signal
9.-
10.blk/yel-power
11.red/blk-power
12.red-power
civic's right side grey plug (10 pins)
1.red/grn-high beam indicator
2.grn/red-e brake signal
3.-
4.-
5.grn/org-check engine indicator
6.blk-ground
8.yel-hot
9.grn-trunk switch
10.blu/wht-seat belt
info from thread #94431 https://honda-tech.com/zerothread?id=94431
1.blu-tach signal
4.-
6.-
8.blk-ground
10.yel-hot
11.-
13.-
2.red/grn-high beam
4.grn/blu-left turn
5.-
6.blk/yel-power
7.red/blk-power
8.red-power
10.grn-trunk switch
12.-
4.grn/blu-left turn
5.wht/blu-charge
7.-
8.blu-tach signal
9.-
10.blk/yel-power
11.red/blk-power
12.red-power
3.-
4.-
6.blk-ground
8.yel-hot
9.grn-trunk switch
HybridHatchC1
May 19, 2004 04:46 PM
h0mesk1let
Apr 17, 2002 08:29 PM
