Removing sound-deadening material.
Old Nov 9, 2005 | 10:33 PM
KOREAN's Avatar
Default Removing sound-deadening material.
I'm in the process of stripping my interior. I realized that there is sound-deadening material all over my car. I tried peeling some of it off, but it's stuck with what seems to be a black adhesive. It's very sticky and tar-like.
How do I get it off? Goo-gone? What's this I hear about dry-ice?
Old Nov 9, 2005 | 10:35 PM
blackANESE's Avatar
Default Re: Removing sound-deadening material. (korean)
Dry ice works wonders
Old Nov 9, 2005 | 10:38 PM
KOREAN's Avatar
Default Re: Removing sound-deadening material. (blackANESE)
Would you be able to tell me the process of using dry ice to remove this stuff? TIA
Old Nov 9, 2005 | 10:39 PM
JDMlyfestyle's Avatar
wear thick gloves.. break up dry ice and throw it on wait about 4-5 mins and just chizzle it off.
95-EJ1's Avatar
just let the dry sit on it for a while...take a hammer and chissle...and it should come right off
Old Nov 9, 2005 | 10:42 PM
KOREAN's Avatar
Default Re: Removing sound-deadening material. (95-EJ1)
i'm trying not to scrape the metal it's sitting on. but i'll find an alternative.
thanks
/thread.
Old Nov 9, 2005 | 10:48 PM
Dry Ice is the only way i would do it.. it freezes everything together.. any other way it will come off like black tar and wont come off 100%
Old Nov 9, 2005 | 10:58 PM
KOREAN's Avatar
Default Re: (JDMlyfestyle)
anyone know where i can get dry ice? baskin robbins?
Old Nov 9, 2005 | 11:15 PM
blackANESE's Avatar
Default Re: (korean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by korean &raquo;</TD></TR><TR><TD CLASS="quote">anyone know where i can get dry ice? baskin robbins? </TD></TR></TABLE>
I actually think you can, but I got it at a supermarket
Old Nov 9, 2005 | 11:17 PM
KOREAN's Avatar
Default Re: (blackANESE)
arite. i'm off to the supermarket tomorrow morning!
Old Nov 14, 2005 | 10:00 PM
MASTRCHANN's Avatar
you can do it without dry ice, you just gotta be willing to work at it a little more. I used a flat head and a hammer, and chisled (sp?) off the padding part. There was a little bit of tar here and there, whatever didn't come off clean the first time around. I happened to have "PB penetrator" (from pepboys) which is like WD40 but supposedly stronger. This stuff practically melted off the left over tar, easy enough to wipe off with little additional scraping required. 45 minutes total for one section right under the pass side rear. Use what ya got, i guess.
Also, scraping along the metal is not a big deal, as long as you slide in at a low angle. If anything, the scratches are extremely light and can be easily sanded of buffed out. I plan to refinish the inside anyway with a new coat of paint.
Old Nov 14, 2005 | 10:02 PM
Chong's Avatar
ballin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackANESE &raquo;</TD></TR><TR><TD CLASS="quote">Dry ice works wonders</TD></TR></TABLE>
there's a write up on this somewhere around here..
Old Nov 14, 2005 | 10:10 PM
Sille98's Avatar
If your talking about the foil with black tar stuff underneath it, peel it then use goo gone. If it is the painted stuff, DRY ICE all the way!
Believe me dry ice did notthing for that foil tar crap that was sitting on top of my fenderwells.
Dry Ice works great pretty much everywhere else...
Old Nov 15, 2005 | 04:21 AM
SlobberGoat's Avatar
Default Re: Removing sound-deadening material. (Sille98)
You'll need:
a blunt screwdriver.
a small hammer.
carb-cleaner & rags for the remaining goo.
a few slabs of beer.
lotsa weekends.
Old Nov 15, 2005 | 05:08 AM
HONDA RR's Avatar
You need paint thinner or jassco
Old Nov 17, 2005 | 12:42 AM
TurboKneeGrow's Avatar
Default Re: Removing sound-deadening material. (HONDA RR)
heres a great write up on it by VX
https://honda-tech.com/zerothread?id=525936
Old Nov 17, 2005 | 05:13 AM
HONDA RR's Avatar
try dry ice
hotimportcrx
Aug 29, 2005 03:14 PM
fOmaNPu
Jul 6, 2004 04:33 AM
DXDOHCVTEC
Sep 1, 2003 02:10 PM
navin
24
Jun 12, 2002 08:54 PM
McD
13
Jan 16, 2002 09:52 AM
