how do you take apart the cig. lighter bezel? need to replace it with a faux carbon fiber one
alright, i removed the coin holder, unscrew 2 screws and pulled it out.
now im stuck...
the cig. lighter unit cannot be removed for ****.
anyone know how?
let me know. thanks
now im stuck...
anyone know how?
let me know. thanks
i know this wont help, by i cam across the same thing,, cant remember how we got past that point lmao
Unplug the wires from the cig lighter back. Then unscrew the gold looking nut around the back of the cig lighter it has 3 large ribs on it. Use pliers. The metal lighter shell will pull forward and then the plastic around the lighter will come off. Hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:JEROME:. »</TD></TR><TR><TD CLASS="quote">Unplug the wires from the cig lighter back. Then unscrew the gold looking nut around the back of the cig lighter it has 3 large ribs on it. Use pliers. The metal lighter shell will pull forward and then the plastic around the lighter will come off. Hope this helps.</TD></TR></TABLE>
yes that did help!
thanks to you, project 1 is accomplished.
now. project 2 - fix/locate oil leak, replace oil pan & gasket, re-align l-bracket, install flywheel cover
project 3 - fix bumper stiffner bolt and bracket
yes that did help!
traded my jdm console for a USDM type r console, then bought some parts from acura dealership and mix and matched some jdm parts to the console and that what you see.
pityocamptes
Paint and Body
21
May 28, 2012 07:42 AM
hi-Powered
Nov 12, 2005 10:55 AM
todaspecsi
Feb 4, 2004 10:47 AM
