4 gal of fuel in tank when gauge reads empty
Old Nov 9, 2005 | 03:11 PM
eda6's Avatar
Default 4 gal of fuel in tank when gauge reads empty
Every manual i've seen says that the hatchback can hold 11.9 gal of fuel.
I've owned my ed6 for 3.5 years and usually i start looking for gas at 1/4 tank. Everytime i refuel my car it takes 6.5-7.0 gallons. Occasionally it will take 8 gallons if i let the needle get closer to "E". Once it took 9 gallons because the pump didn't shut off and it overflowed.
I found an 88 civic owners manual at the junkyard yesterday. Flipped thought it and when i got to the page about gages, i learned that when the needle reads empty there is 4 gallons left in the tank.
I never knew this so i figured i'd share.
*edit* when the needle reads empty there is 4 liters (1.1 gallons) left in the tank
Modified by eda6 at 8:19 PM 11/9/2005
Old Nov 9, 2005 | 03:12 PM
kulangot's Avatar
Default Re: 4 gal of fuel in tank when gauge reads empty (eda6)
good info...i never go any lower then 1/4..
Old Nov 9, 2005 | 03:20 PM
J4k3's Avatar
Default Re: 4 gal of fuel in tank when gauge reads empty (kulangot)
is that just on civics or would it include 89 crx's also??
Old Nov 9, 2005 | 03:50 PM
Crx Jimmy's Avatar
i believe its 4 litres not gallons
Old Nov 9, 2005 | 03:52 PM
temp's Avatar
Default Re: 4 gal of fuel in tank when gauge reads empty (Crx Jimmy)
just FYI gas stations rape you, i went to one this morning when my low fuel light is on on my TL it takes almost 15 gallons at AMPM, i went to valero and it took 13.5.....wtf?
Old Nov 9, 2005 | 03:58 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">i believe its 4 litres not gallons</TD></TR></TABLE>
I checked the book again and you're correct. 4 liters=1.1 gallons
fifao
Jun 7, 2016 08:51 PM
brendan310
Sep 22, 2015 11:00 AM
vrrodri
Jun 29, 2011 05:32 AM
drwoody
May 28, 2010 05:52 PM
kailiwela44
Honda Civic (2001 - 2005)
12
May 3, 2009 01:56 PM
