Will it be safe to run B20Vtec like that?
Old Nov 9, 2005 | 03:04 PM
ATSEK4's Avatar
Default Will it be safe to run B20Vtec like that?
hi guys,
EK4 civic Sell
got a B16A head + ITR TB IM and head been pored and polished, Toda A spec cams, Toda Gear, Toda Valve Springs, new stock retainers and stem seals, stock vavles.
OEM crv head gasket, 85mm CP "12.5 CR" forged Pistons, Eagle Rods with APR bolts, Stock Sleeves with 85mm bore. All blue printed and balanced, Spoon Oil pump, and Endyn block gride (sit under the crank). all stock injectors, only run FPR.
EK9 gear box, stock LSD and ATS 4.929 Final drive. Apexi Power FC
Thanks !
Old Nov 9, 2005 | 03:06 PM
97L-esVeeTeg's Avatar
Default Re: Will it be safe to run B20Vtec like that? (ATSEK4)
Stock injectors arent going to cut it.
Old Nov 9, 2005 | 04:02 PM
Phatch99's Avatar
Default Re: Will it be safe to run B20Vtec like that? (97L-esVeeTeg)
stock sleeves bored out to 85mm??? wit all that $$$ invested in that build i'd sleeve the block u don't want to have to do that again later. just my .02
Modified by Phatch99 at 7:14 PM 11/9/2005
Old Nov 11, 2005 | 09:20 AM
DIFFUT'S INC.'s Avatar
Default Re: Will it be safe to run B20Vtec like that? (Phatch99)
got some Rc's 310 and what ecu system you useing ? also tune it ASAP.
Old Nov 11, 2005 | 11:45 AM
7k rdlne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatch99 &raquo;</TD></TR><TR><TD CLASS="quote">stock sleeves bored out to 85mm??? wit all that $$$ invested in that build i'd sleeve the block u don't want to have to do that again later. just my .02
Modified by Phatch99 at 7:14 PM 11/9/2005</TD></TR></TABLE>
Thats what i was thinking, stock b20 sleeves are weak enough then to bore it out even more, too risky for me, hope it works out good for you though
magicm
Oct 9, 2013 09:11 PM
katas
13
Oct 31, 2008 05:03 AM
B16b-EJ8
94
Aug 25, 2006 08:25 AM
tech6804
Oct 5, 2004 04:00 PM
NAB20C5
Aug 24, 2001 11:53 AM
