New tires?
I need to replace my tires again. I'm on my forth set of the Dunlop 9000's (205/45/16's) http://www.dunloptire.com/sp9000/
and had one set of the 8000's http://www.dunloptire.com/tires/SP_8000.html
(that I didn't like) on my 97 Teg. I'm considering on getting a differnt set this time. I don't need max perfomance and perfer a tire that has a longer tread rate then the 9000 which is 280 and still have the perfomance of the 9000's. I need a high tread rate cause I put a lot miles on my car for work. Does anyone know of such a set or a test done a sevral tires from a non partial source? Please list all detail's (web sites,model #'s,why,tread rates....). Also need a tire that does good in all conditions. Beleave it or not the 9000 is a pretty good all weather tire and I live in Buffalo,NY to prove I know it is.
The bridgestone Re730 have a 300 tread wear probely the same in price but much better performance wise If your looking to sacrifise alittle performance for a long lasting performance tire then I would go the BFGOODRICH g-force KDWS basically an all season performance tire that wont kill the pocket I believe they have a 400 tread wear the only other one that I know of is a bit pricey is the Michelin Pilot A/S they too come witha 400 tread but they will cost you a **** load of money clsoe to 850 dollars for a set hope this helps Ohh yea bye the way when you purchass Z rated tires from costco they come with a road hazard warrenty included so everytime there is a nail in your tire you get a new one no questions asked the reason being they came up with a policy thatit is unsafe to patch or plug a Z rated tire HOpe this helps
Hmm I need to do some home work or does nay one have more info on the Bridgestone Re730's?
1) http://www.tirerack.com/tires/bridgestone/bs_re730.jsp
2) http://www.carreview.com/Tires/Bridg...2_1577crx.aspx
3) http://www.corvetteforum.com/reviews...259&TopicID=16
4) http://www.240sx.org/links/product-r...tires/will.htm
It looks like a better tire at first look/read then the Dunlop 9000.
Thank you (95CivicEX)
Look at getting the Bridgestone Potenza S-02 Pole Position or Potenza S-03 Pole Position
Or the
Michelin - Pilot Sport
Both are extremly great tires. But they are very expensive.
Or the
