Right wheel hop when turning left...
Just checkin up on here before i rip anything apart....when i turn right everything is flawless, for some reason when turning left, my right front wheel hops, starting to get annoying, im sure someone will know what it is, hook a brotha up
I would check for a blown shock at that corner. Also inspect your bushings for tears, and make sure all the balljoints are tight (upper, lower, inner & outer tie rods)...
When you work on your suspension do you remember to preload the suspension with the cars full weight before you tighten down the bolts located at each bushing?
Hell yeah you have to do that for every bushing! Every bushing with a bolt going through it's center that is. That only excludes the rear trailing arm bushing & the rear inner upper control arm bushing...
The sucky thing is that after you lower your car you have re-do EVERY bushing. Otherwise you will experience rapid bushing wear...
Homesickelian
Mar 5, 2007 04:06 AM
alfaaay
Suspension & Brakes
Oct 10, 2006 04:59 PM
