trouble with 5th gen interior, easy, please help
Ok, well I really need to swap out my cluster in my accord since the tach is not working on the stock one, I bought a new one but like most Hondas and Acuras I removed the top screws and began to pull on the bezel. But the top of the bezel and top half of the vent on the left side comes loose, nothing else.
HOW DO I FREAKIN TAKE THAT THING OUT? ITS GETTING DARK AND I HAVE TO GET THIS DONE FOR THE MORNING. PLEASE HELP. TIA
First off, get a manual.
To pull the cluster, you basically have to dissasemble the entire dash. To much to post here so go to AutoZone and grab a Haynes
The screws which require removal to reach the cluster are:
1) Under the Cruise/Sunroof switch (requires switch removal to gain access)
2) Under the Rear Defogger Control Switch (requires switch removal to gain access)
3) Above the Clock (facing up) (requires removal of Console trim plate to gain access)
4) Above Cluster facing up (under sun hood)
It will come loose after that. Be ready for the AC/Heater Control to come with it
P
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams »</TD></TR><TR><TD CLASS="quote">The screws which require removal to reach the cluster are:
P</TD></TR></TABLE>
thanks you dude
P</TD></TR></TABLE>
thanks you dude
m1ndless
Oct 8, 2006 07:08 PM
4g4me
Apr 23, 2002 02:03 PM
