Does 97 b18c1 block fit a 93 LS motor?
Old Nov 9, 2005 | 11:39 AM
teo112782's Avatar
Default Does 97 b18c1 block fit a 93 LS motor?
I want to swap a new engine. I have a 97 integra gsr. it used to have a b18c1 motor in it. It got stolen and they took the whole motor plus the ECU. I was going to put in a 93 LS motor, I was wondering if the b18c1 block fit that motor. If it fit, I would need a new 97gsr ECU too right?
Old Nov 9, 2005 | 12:00 PM
BlackDAy's Avatar
Default Re: Does 97 b18c1 block fit a 93 LS motor? (teo112782)
that depends on what u want to do. at this point, you can, since they took the whole motor & ecu, run an obd2 ls ecu w/ obd2 injectors/dizzy. Or u can convert to obd1. If u plan on boosting sometime soon, i would just convert to obd1 now. (more stand alone options).
Old Nov 10, 2005 | 09:48 AM
teo112782's Avatar
Default Re: Does 97 b18c1 block fit a 93 LS motor? (BlackDAy)
so I can just straight put in the 93 LS motor, using the the obd1 ecu from it too? Woiuld I need to know anything else?
I would only need the obd2 if I install the b18c1 block right?
Old Nov 10, 2005 | 09:50 AM
teo112782's Avatar
If you happen to know, what would be the best modification for what I have that's money saving?
Thanks
Old Nov 10, 2005 | 10:20 AM
BlackDAy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teo112782 &raquo;</TD></TR><TR><TD CLASS="quote">so I can just straight put in the 93 LS motor, using the the obd1 ecu from it too? Woiuld I need to know anything else?
I would only need the obd2 if I install the b18c1 block right?</TD></TR></TABLE>
Well, you would need to have matching obd1 injectors and dizzy to go w/the ecu. u might need to convert the wiring harness from obd2 on ur car to obd1 for the ecu.
U can use obd2 on ur ls, but like i said, you would need obd2 injectors and dizzy to match the ecu obd...in other words, whatever obd u have, you need to have matching injectors, dizzy, and ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teo112782 &raquo;</TD></TR><TR><TD CLASS="quote">If you happen to know, what would be the best modification for what I have that's money saving?
Thanks</TD></TR></TABLE>
intake.
Old Nov 10, 2005 | 10:33 AM
TheBobFather's Avatar
From the sounds of it, you sound a little under educated, even on the basics. Please do alot of reading and reshearching! The search button is your best friend for most ?'s. Enjoy your honda!
str8drift
Oct 31, 2007 03:34 PM
Jhonny Ricer
May 28, 2007 12:02 AM
G MoNeY Ej1
Apr 28, 2007 08:53 AM
wheelmaneg6
Aug 11, 2006 07:27 PM
Skunk2Civic94
Jun 4, 2002 05:46 PM
