cam gear cover
Old Nov 9, 2005 | 11:28 AM
crx69's Avatar
Default cam gear cover
i swapped the engine in my 91 crx and i wanna get the zc hood because i noticed that the stock hood is rubbing on the cam gear cover so i was wondering if it is safe to drive without the cover and 2 does anyone know where i can find a zc hood
thanx
Old Nov 9, 2005 | 11:31 AM
kulangot's Avatar
Default Re: cam gear cover (crx69)
what motor did you put in? are you sure its the cam cover? and not the clutch cable?
Old Nov 9, 2005 | 12:25 PM
31flavorscivic's Avatar
Default Re: cam gear cover (kulangot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulangot &raquo;</TD></TR><TR><TD CLASS="quote">what motor did you put in? are you sure its the cam cover? and not the clutch cable?</TD></TR></TABLE>
Mine rubs too. On some civics and CRXs the timing belt cover on the DOHC ZC rubs the hood. I just deal with it and press down on my hood whenever I have to open it. My friend ran without a timing belt cover in his DOHC ZC, but I just don't like the idea of doing it.
As for a ZC hood, I'm looking too.
p.s. happy 1000th post to me
edit: I assume you are running a DOHC ZC??
Old Nov 9, 2005 | 07:17 PM
crx69's Avatar
Default Re: cam gear cover (31flavorscivic)
in deed dohc zc. the only reason im askin is cuz i saw someone jus left it on and it rubbed the timing belt so hard it started missin teeth on the cam gears and slipping.
drewboy
13
Jan 11, 2006 01:56 PM
crxzcracer
Apr 1, 2004 02:05 PM
JackAcc
16
Jul 13, 2003 02:04 PM
crx_ef8
22
Jan 21, 2003 05:38 PM
l0p3z
Sep 23, 2001 10:15 PM
