WTB: Stock 96-00 Civic Shocks/springs - and rear drum setup or a rear disc conv.
Old Nov 9, 2005 | 10:58 AM
bradykiller's Avatar
Default WTB: Stock 96-00 Civic Shocks/springs - and rear drum setup or a rear disc conv.
As it stats.. i need all 4 stock shocks/springs or something that's a cheap replacement
And i need a rear drum setup including the rear trailing arms and LCAs, and brake lines.
Or a rear disc conversion including all the same things. Thanks in advance, help me get my shell running!
Old Nov 10, 2005 | 09:18 AM
Default Re: WTB: Stock 96-00 Civic Shocks/springs - and rear drum setup or a rear disc conv. (bradykiller)
BUMP! I wanna get my car runnin! hook it up!
Old Nov 10, 2005 | 10:13 AM
Odiedogcx's Avatar
AIRBORNE
I have 2000 Si springs ... $40. LMK if interested
Old Nov 10, 2005 | 11:27 AM
Default Re: WTB: Stock 96-00 Civic Shocks/springs - and rear drum setup or a rear disc conv. (Odiedogcx)
Got a set of shocks/springs, thanks though!
Now i need either a rear disc conversion or a rear drum setup! Someone hook me up i need to get my car driveable!
Old Nov 14, 2005 | 07:50 AM
Tex Blackwell's Avatar
i have everything you need for the rear disk conversion,
trailing arms, has brembo crossdrilled and slotted rotors, pretty new, came off a 00si, then the car is using a different suspension, ebrake cables, prop valve, brake lines, everything you will need to just bolt it in,
pm me if you still need it
tyfoxx0608
11
Mar 12, 2012 05:02 AM
Nuggets4
Suspension & Brakes
Dec 17, 2010 11:42 AM
jde_07
Jan 25, 2005 10:36 AM
