d16z6 into 92 cx hatchback
im helping a buddy put a d16z6 from a civic ex into his cx hatchback...car didnt have vtec before...if i have the ecu to put in with the swap do we need to wire for vtec...and if so can someone point me in the right direction to a step by step guide...thanks in advance
pretty sure you have to wire it for vtec since the cx wasnt. if you do look for the writeup for mini me that bauley civic did and it shows how to do it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedd2286 »</TD></TR><TR><TD CLASS="quote">i read somewhere that all 92 civics are pre-wired for vtec...</TD></TR></TABLE>
i thought i heard that also..
92 civics are pre-wired from the ecu to the shock tower. u still need to run 3 wires for vtec and for the 4-wire o2 sensor. you can either splice your stock harness or get a 92-95 ex/si engine harness and it'll be plug and play!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa »</TD></TR><TR><TD CLASS="quote">d16z6...p28 doesn't have knock sensor. Someone correct me if I'm wrong.</TD></TR></TABLE>
I'd correct you if you were wrong, but you're right
from what i know, that is correct.
ok so that guy that posted the pics was wrong about the knock snsor but i still have to wire for the 4 wire 02 sensor right? anyone tell me how to do it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedd2286 »</TD></TR><TR><TD CLASS="quote">ok so that guy that posted the pics was wrong about the knock snsor but i still have to wire for the 4 wire 02 sensor right? anyone tell me how to do it</TD></TR></TABLE>
dude, it says WIRE KNOCK SENSOR, IF APPLICABLE
if your gonna sit there and bitch about it...dont post...all i was asking for was help, not to be flamed, i just need help wiring the 4 wire o2 sensor can anyone help me?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedd2286 »</TD></TR><TR><TD CLASS="quote">if your gonna sit there and bitch about it...dont post...all i was asking for was help, not to be flamed, i just need help wiring the 4 wire o2 sensor can anyone help me?</TD></TR></TABLE>
You're getting flamed, ******.
SEARCH this has been done a million times already by a million people and their grandmas.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hAcHiEeg6 »</TD></TR><TR><TD CLASS="quote">is the 94 cx chassis wired for v tech or is it only the 92</TD></TR></TABLE>
only 92's
only 92's
trooper0641
21
Oct 26, 2003 09:54 PM
