Turn signal not turning off with momo wheel?
Old Nov 9, 2005 | 09:15 AM
egvtec's Avatar
Default Turn signal not turning off with momo wheel?
I installed a momo steering wheel on my 96 hatch and when i removed the air bag and un hooked the wires i must have removed or unplugged something that allows the turn signal to turn off when it hits that certain point when u turn your steering wheel. Anyone know what i did that is not allowing this to work now? I have to maually turn it off with my hand and this gets annoying.
Old Nov 9, 2005 | 09:17 AM
revvin9k's Avatar
Default Re: Turn signal not turning off with momo wheel? (egvtec)
It's normal when you install aftermarket wheels. Trust me, you'll get used to doing it your self.
92ehatch's Avatar
the turn signals are tied into the hazard lights, so it could be the hazard switch or wires to the hazard switch. or i guess the lever on the steering wheel could have some issues that occured during the install. i guess the best thing is the take the wheel off again and check all everything is ok.
this has got to be annoying as well, not only to you but other drivers. hope someone can give you better answers than i did. good luck with it.
EDIT, i didnt read everything, you have to manually do it yourself, that sounds about normal, i guess you culd fab a bar or something that will do it for you, otherwise that dont sound that bad
Old Nov 9, 2005 | 09:35 AM
egvtec's Avatar
I had a momo wheel in my old black eg hatch and it worked fine??????
Old Nov 9, 2005 | 11:52 AM
egvtec's Avatar
Any fixes?
Old Nov 9, 2005 | 12:24 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egvtec &raquo;</TD></TR><TR><TD CLASS="quote">I installed a momo steering wheel on my 96 hatch and when i removed the air bag and un hooked the wires i must have removed or unplugged something that allows the turn signal to turn off </TD></TR></TABLE>
Did you remove or damage the turn signal cancel cam?
Old Nov 9, 2005 | 01:41 PM
egvtec's Avatar
Default Re: Turn signal not turning off with momo wheel? (Chiovnidca)
not sure what that is?
Old Nov 10, 2005 | 12:20 AM
skankz_em1's Avatar
did you tighten the 19mm that holds the hub on? mine wasnt on tight and it was doing that also that was the only thing that was wrong wiith mine
Old Nov 10, 2005 | 11:34 AM
egvtec's Avatar
Default Re: Turn signal not turning off with momo wheel? (coronaboylbc)
its tight. was your wheel all loose cause mine is on tight
i need to fix this ****!
Old Nov 10, 2005 | 11:37 AM
riceburnerryan's Avatar
mine does the samn thing... it was a normal thing to happen.. its not that bad is it?
Old Nov 10, 2005 | 11:39 AM
00CivicGirl's Avatar
Default Re: (riceburnerryan)
dont you have to remove the clock spring from behind the wheel? if so that clock spring is what makes your signal turn off after you have turned
Old Nov 10, 2005 | 11:42 AM
egvtec's Avatar
Default Re: (00CivicGirl)
I removed the white SRS thing and thats it other then the harness. maybe i should look and try and see what i took out. its not that bad just bothers me when stuff doesnt work factory.
Old Nov 10, 2005 | 12:05 PM
skankz_em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egvtec &raquo;</TD></TR><TR><TD CLASS="quote">its tight. was your wheel all loose cause mine is on tight
i need to fix this ****!</TD></TR></TABLE>
mine was all loose, and when i tightened it, it stopped doing that
Old Nov 10, 2005 | 12:11 PM
EGmikeH22's Avatar
* B A N N E D *
my integra wheel doesnt trip the turn signals like it should either.
subscribing.
Old Nov 10, 2005 | 12:20 PM
turbotime's Avatar
my guess is you didint install the signal cancel plate, or if you did you put it int he wrong way.
Its like a white plastic plate that is at the base of the hub.
SigmaOmega's Avatar
im lookin up this in the Haynes manual, the reason you may need to fix that is because if you decide to move to a state with a stringent inspection check, it would fail. It would fail in Maryland for a non stock steering wheel, and the self cancel not working. So, ill see what Haynes says.....
Old Nov 10, 2005 | 12:24 PM
freakin_eLRoD's Avatar
mine works just fine. i just remember screwing with it a few times then the self cancel just started to work
Old Nov 10, 2005 | 08:36 PM
egvtec's Avatar
Im gonna play with this tomarrow i took out a white piece of plastic maybe ill reinstall it.
Old Nov 11, 2005 | 03:35 PM
SigmaOmega's Avatar
it really has nothing on self cancel in the Haynes repair manual (maybe i need the upgrade manual they published)....o well i tried, i really have no clue why some ppl's work and others' dont.
see vick
12
Mar 5, 2021 05:49 AM
russianswty
Mar 5, 2007 10:27 AM
iheartintegras
Jan 31, 2007 12:14 AM
TheSSG
Apr 22, 2004 08:19 AM
EARLdaSQUIRREL
Jan 16, 2004 06:15 PM
