A question to type r owners
I just did a tranny swap from a gsr to a type r tranny with exedy flywheel and clutch. The used transmission i installed is just not smooth. When I shift into gear it does not go straight in it kind of stops right before then I push harder and it goes in, u know what I mean? Is this normal?
you may want to check your pressure plate... or the springs in hub of the clutch... I had the same issues and thats what went wrong with mine... however every situation is different..
just a heads up in case it helps you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeRR »</TD></TR><TR><TD CLASS="quote">you may want to check your pressure plate... or the springs in hub of the clutch... I had the same issues and thats what went wrong with mine... however every situation is different.. </TD></TR></TABLE>
Agreed. Drop the tranny and inspect the clutch. Since the original poster made no mention of grinds, or mention of it being an issue shifting into one specific gear, I really dont think its the syncro's.
ahhhh... i had hell of a time dropping the tranny and i dont want to do it again. Im going to try adjusting the pedal tomorrow and hopefully that will work. Thanks for all the good info.
