My car shakes like a Vibrator!!!!
Old Nov 8, 2005 | 11:19 PM
maurob18a1's Avatar
Default My car shakes like a Vibrator!!!!
DC4/B18B1/Turbo/LS transmission/ACT Street-Strip Clutch
Okay, so on accel. my car vibrates really badly. On deccel. its fine. My right side wheel was shaking while I hade the car on jack stands, which led me to change the tie rods and the rack & pinon (got it aligned and the tires balanced). Drove the car and it still Shook. So then I decided to replace both CV axles. Drove and it still shook. I saw that the motor mount on the tranny side was bad, so I bought a Hasport mount (Auto to manual convertion, so I decided to by the mount that I needed to begin with). Drove the car... still shook! So then I decided to change the drivers side mount with a Hasport mount as well hoping that the mount was the problem... Wrong again .. The rear mount and the stabilizer mounts have inserts, so those are okay. I am at the end of my witz. I dont know where the vibration is coming from. The last thing that I could think of is the Transmission's differencial being bad (I hope that is not the case). Any suggestions?
Old Nov 9, 2005 | 12:13 AM
brad.'s Avatar
Default Re: My car shakes like a Vibrator!!!! (maurob18a1)
How do you know what a vibrator shakes like?
Anyway, ever think about the problem being in the hub?
maybe your bearing needs to be changed
Modified by [626]96.GSR at 9:39 PM 11/9/2005
Old Nov 9, 2005 | 04:42 PM
yee SERIOUS's Avatar
Default Re: My car shakes like a Vibrator!!!! ([626]96.GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [626 &raquo;</TD></TR><TR><TD CLASS="quote">96.GSR]How do you know what a vibrator shakes like? </TD></TR></TABLE>
that's what i thought. and then i thought about his problem. check your lug nuts silly. just kidding. it may be your tranny going out. has it ever had a problem before?
Old Nov 9, 2005 | 06:36 PM
dudefella's Avatar
Whip out a vibrator when you're going down on your girl and her eyes'll light up like it's Christmas
Old Nov 9, 2005 | 06:38 PM
loudassVTEC's Avatar
Default Re: My car shakes like a Vibrator!!!! (dudefella)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dudefella &raquo;</TD></TR><TR><TD CLASS="quote">
Whip out a vibrator when you're going down on your girl and her eyes'll light up like it's Christmas </TD></TR></TABLE>
lmmfao
Old Nov 9, 2005 | 06:40 PM
Wayne_Curr's Avatar
this happened with my friend's scirocco, tranny went out one day while haulin ***. Its your diff. i'm pretty sure if you've alrdy changed your CVs. Change tranny fluid and see if theres lots of chunks of metal stuck to the magnet.
Old Nov 9, 2005 | 07:20 PM
GoCarInteg's Avatar
what i'm curious about is why the heck do you have a vibrator in the first place? lol
Old Nov 9, 2005 | 07:28 PM
Default Re: My car shakes like a Vibrator!!!! (GoCarInteg)
You would have one to use on your girlfriend when she comes over for some fun. By no means does owning a vibrator make you gay, or imply that you use it on yourself.
Old Nov 9, 2005 | 08:42 PM
brad.'s Avatar
Default Re: My car shakes like a Vibrator!!!! (loudassVTEC)
I won't lie, I have one. She brought one to keep here at my house for "sessions"
ANYWAY, I'm still wondering if it could be a problem with the hub/spindle.
Old Nov 9, 2005 | 09:19 PM
yrethguad's Avatar
When I had a bad bearing it caused a vibration and sound consistant with wheel speed, not based on acceleration rate. Sliding sideways into a ditch caused the failure.
Old Nov 9, 2005 | 09:38 PM
blackdelslo's Avatar
Default Re: (yrethguad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> "sessions"</TD></TR></TABLE>
Oh so thats what there calling it these days... I never saw anything wrong with saying "my girlfriend is coming over to expletive the **** out of me."
Old Nov 9, 2005 | 10:34 PM
LSTEG96's Avatar
axles. id put money on it
Old Nov 9, 2005 | 11:04 PM
maurob18a1's Avatar
I am buying a tranny from a friend, so I HOPE that is the problem.... Im also thinking that my brakes may be warped... I really dont thing think that the wheel bearings are bad because when I changed the axles that is one of the things that I checked... the Hub spun smoothly. I thought that the axles may have been defective as well, but to be honest, the "before & after" shake is the same.
Old Nov 9, 2005 | 11:55 PM
dudefella's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoCarInteg &raquo;</TD></TR><TR><TD CLASS="quote">what i'm curious about is why the heck do you have a vibrator in the first place? lol </TD></TR></TABLE>
Some random left it at my place.... anywho, I'd have bought one anyway. Ladies love 'em!
Old Nov 10, 2005 | 08:23 PM
missionaryrider's Avatar
ok u have inserts and hasport mounts=motor not moving power to the ground =car shakes=feels like race car
Old Nov 11, 2005 | 05:42 PM
Sam92Teg's Avatar
Default Re: (missionaryrider)
I had a severe vibration only on acceleration and did all the things you mentioned. Then I figured it was the differential and bought a new one and installed with my new clutch and flywheel. After reinstalling the tranny, with new diff and diff bearings and new axles, the vibration was minimal. But only after a couple of weeks it was just as bad as before. I was at my wits end, just like you.
I then installed a new rear torque mount and new axles again, and problem was gone and hasn't come back. If the rear torque mount allows the engine and tranny to move to much, the inner CV joints absorb way too much angle and end up failing. Also if your car is lowered as most of ours are, this increases the bad angle as well. Because of the play in the mount, my CV axles kept having inner joint failure that caused a very bad vibration on acceleration.
The worn inner joint on the axle is the cause of the vibration and the mount is the catalyst for the failure. I see that you have inserts, but if the mount is torn, the insert might still allow too much movement. Good luck on your car, hope this helps.
Old Nov 13, 2005 | 01:01 AM
maurob18a1's Avatar
thanks for the info. I just bought a new tranny, so we will see what happens
Old Nov 13, 2005 | 10:05 AM
Sifu's Avatar
Man the bitches must love riding in your car...
Old Nov 13, 2005 | 03:20 PM
opiumdaze's Avatar
Default Re: (Sifu)
I'm having the exact same problems as you are!... Let me know what happens with the new tranny
Old Nov 13, 2005 | 03:23 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
my friends auto 4 door teg shakes like krazy too on accel.. he thinks it's his axels or something.. not shore yet, find out and hit us up with it!
Old Nov 15, 2005 | 11:15 AM
Zion-I's Avatar
I had that problem before, I found it I had bad CV boots.
Old Nov 15, 2005 | 11:39 AM
CRXb18Turbo's Avatar
Default Re: (OldDc2)
LMK whats the update
Old Nov 15, 2005 | 01:49 PM
maurob18a1's Avatar
I will be changing the tranny this weekend.. I will update then.
Old Nov 15, 2005 | 02:01 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (maurob18a1)
What kind of axles did you put on? If rebuilt, then they are probably still the problem. I replaced my axles 4 times in about 2 months because I was putting on CCT-brand rebuilts, and it took that many sets to actually get a good set that did NOT vibrate during acceleration.
Brakes is not it, you wouldn't feel that during acceleration.
Get under the car and try to move the inner CV joints and see if there's any free-play.
Old Nov 16, 2005 | 12:26 AM
maurob18a1's Avatar
yeah they are rebuilds... Im going to take them out tomorrow before I replace the tranny
