I got 195/50/15 tires right now can I go 205/50/15 ?
Old Nov 8, 2005 | 09:20 PM
tdo's Avatar
tdo
Default I got 195/50/15 tires right now can I go 205/50/15 ?
i found some 205/50/15 and wanted to know if this is ok to get?
i got 195/50/15 right now.
Old Nov 9, 2005 | 07:35 AM
Erik_Pb_Foot's Avatar
New User
Default Re: I got 195/50/15 tires right now can I go 205/50/15 ? (tdo)
so long as your car isn't dumped and/or your wheel offset isn't "bad"
Old Nov 9, 2005 | 08:20 AM
nsxtasy's Avatar
H-T Order of Merit
You can switch to 205/50. However, depending on the car, 195/50-15 may be a better fit for your car. For example, the outer diameter may be closer to stock than 205/50, so that it will maintain the accuracy of your speedometer and odometer.
195/50-15 is a better fit for most older Civics that came stock with 175/70-13 or 185/60-14 tires.
195/55-15 is a better fit for most Integras and some newer Civics that came stock with 195/55-15 or 185/65-14 tires.
205/50-15 may be used as well, but may throw off your speedometer/odometer. One advantage of 205/50-15 is that it may be the only 15" size available that works for your car. This is true for many track tires and also for the Dunlop Direzza DZ101 tire.
What kind of car do you have? (Make, model, version, year)
Old Nov 9, 2005 | 08:25 AM
New User
Default Re: I got 195/50/15 tires right now can I go 205/50/15 ? (nsxtasy)
my new 205-50-15 azenis are noticeably bigger than my 195-50-15 cheap-o wyndstars... many people don't realize that the sidewall is 50 on each but that is not a measurement of height, it's a percentage of stuff.... my 205-50's have a bigger sidewall than my 195-50's... for example...
Old Nov 9, 2005 | 08:39 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: I got 195/50/15 tires right now can I go 205/50/15 ? (Erik_Pb_Foot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik_Pb_Foot &raquo;</TD></TR><TR><TD CLASS="quote">my new 205-50-15 azenis are noticeably bigger than my 195-50-15 cheap-o wyndstars... many people don't realize that the sidewall is 50 on each but that is not a measurement of height, it's a percentage of stuff.... my 205-50's have a bigger sidewall than my 195-50's... for example...</TD></TR></TABLE>
50 is called the "aspect ratio" and specifies the relationship between the sidewall height and the tread width. For example, a 195/50-15 tire has tread that is 195 mm wide, and the sidewall height is 50 percent of 195 mm, or 97.5 mm.
Old Nov 9, 2005 | 10:54 AM
New User
basically what i was trying to say without being engineer techical
Old Nov 9, 2005 | 03:29 PM
tdo's Avatar
tdo
i got a eh2 and my ride height ride now is almost stock, but not for long.
i found some azenis but its 205/50/15. i wanted to know if they would fit before i buy them.
Old Nov 9, 2005 | 04:24 PM
New User
stock ride height they would be fine... unless you had some addball wheels. what wheels are you running?
Old Nov 9, 2005 | 05:24 PM
tdo's Avatar
tdo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik_Pb_Foot &raquo;</TD></TR><TR><TD CLASS="quote">stock ride height they would be fine... unless you had some addball wheels. what wheels are you running?</TD></TR></TABLE>
im running some advan rg's.
Old Nov 9, 2005 | 06:59 PM
xintegr's Avatar
would 205/50/15 fit a 98 integra wif rotas. the car is drop pretty low. no gap between tires and fender
Old Nov 9, 2005 | 10:16 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (xintegr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdo &raquo;</TD></TR><TR><TD CLASS="quote">i got a eh2 and my ride height ride now is almost stock, but not for long.
i found some azenis but its 205/50/15. i wanted to know if they would fit before i buy them.</TD></TR></TABLE>
Rubbing is always a risk when you combine (a) a tire that is wider than stock AND (b) a tire whose outer diameter is greater than stock AND (c) a lowered car. It's even worse if they are the old Azenis (RT-215), which were notorious for being larger than other tires of the same 205/50-15 size; I'm not sure if that's true of the new Azenis (RT-615) or not.
You'll have to try it to find out. 195/50-15 would certainly be a better choice for your car, but it's not available yet in the new Azenis.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xintegr &raquo;</TD></TR><TR><TD CLASS="quote">would 205/50/15 fit a 98 integra wif rotas. the car is drop pretty low. no gap between tires and fender</TD></TR></TABLE>
It should; it's actually smaller in outer diameter than the stock size on your Integra. But I would stick with 195/55-15 (stock size for SE/GSR/ITR) if it's available in the tire you want.
Old Nov 10, 2005 | 08:14 AM
doh240's Avatar
195/50/15 to 205/50/15 isnt that big of a deal, unless your car is super duper slammed, within mm's of rubbing
you can google that tire calculator site, pretty cool tool, either from the miata site or some tire shop site (discount tire/tiresdirect, forgot which one...)
Old Nov 10, 2005 | 08:53 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: I got 195/50/15 tires right now can I go 205/50/15 ? (doh240)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doh240 &raquo;</TD></TR><TR><TD CLASS="quote">you can google that tire calculator site, pretty cool tool, either from the miata site or some tire shop site (discount tire/tiresdirect, forgot which one...)</TD></TR></TABLE>
You can find a link to it in the "Forum Rules and FAQ" topic which is stickied at the top of this forum.
Old Nov 11, 2005 | 05:01 PM
SOHCmaster's Avatar
Im running 205/50/15 on 00 civic coupe with Skunk2 racing springs and its low as hell and the rears do rub in rard corners in the fenderwell from the body flex, nothing to bad, but I hear it. I know a camber kit would make front and rear touch fenders.
k3ntegra
Apr 10, 2014 07:34 PM
SpeedingHatch
Mar 10, 2006 06:48 AM
Timmy!
Aug 12, 2005 11:35 AM
SiC CiViC
Sep 15, 2002 03:04 PM
Chaze*R
Jul 23, 2002 10:33 PM
