0b0 v-tech spudering
Old Nov 8, 2005 | 09:19 PM
cbr900rr33's Avatar
Default 0b0 v-tech spudering
I have a 1991 integra, I swaped a B16a1 into it. The engine runs fine and throws no codes but as soon as v-tech hits it spuders(hesatation). It spuders threw 5000-6000rpms then after it passes 6000 it feels like it starts to run smoother. By the way the v-tech sounds really loud, maybe not normal?
Old Nov 9, 2005 | 05:17 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: 0b0 v-tech spudering (cbr900rr33)
It is spelled VTEC (there's no H).
Do you have any modifications to the new engine you swapped in? Totally stock? What ECU are you using?
Old Nov 9, 2005 | 05:19 AM
Rajin's Avatar
Default Re: 0b0 v-tech spudering (shamoo)
I'm figuring you mean sputters.
Check the ECU definitely.
Old Nov 9, 2005 | 08:44 AM
loudassVTEC's Avatar
Default Re: 0b0 v-tech spudering (Rajin)
Check both the ignition timing and cam timing.
Old Nov 10, 2005 | 10:08 AM
cbr900rr33's Avatar
The engine is stock, i mean i have a iceman intake but thats it. My ecu is a pr3. My friend has the same ecu, and i borrowed his and the same problem accured. When I first installed the engine i was throwing a code for the knock sensor, then i replaced the knock senor with a new one. The same code came up, so i ran a independent wire from the knock senor to the ecu. After doing this the ecu stoped throwing any codes. I'm still having the sputtering problem.
Old Nov 10, 2005 | 10:28 AM
sounds like timing to me
Old Nov 10, 2005 | 10:31 AM
BlackDAy's Avatar
Default Re: 0b0 v-tech spudering (loudassVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC &raquo;</TD></TR><TR><TD CLASS="quote">sounds like timing to me</TD></TR></TABLE>
longshot
Jul 16, 2008 03:09 PM
Mr.Meowsome
Aug 1, 2007 04:14 PM
ninkei
Nov 15, 2005 04:45 PM
TRhatchCRAP
Aug 27, 2003 07:01 AM
tek_civic
Aug 8, 2003 03:36 PM
