Leaving water cooled turbo oil cooled?
Old Nov 8, 2005 | 08:21 PM
O16581724 5 2 5's Avatar
Default Leaving water cooled turbo oil cooled?
Just curious the negative effects of not running water through one intended for it, i was running a turbo with no option for water and i liked the peace of mind of one less thing to possibly go wrong.
Old Nov 9, 2005 | 10:28 PM
Default Re: Leaving water cooled turbo oil cooled? (O16581724 5 2 5)
Old Nov 10, 2005 | 12:21 AM
nevin's Avatar
it will be fine without it
Old Nov 10, 2005 | 07:14 AM
elpiar's Avatar
Default Re: (nevin)
why not connect it if it's there.
Will help cool down so you dont need a turbo timer that bad unless driving really hard.
Old Nov 10, 2005 | 07:20 AM
EJ1 wilcox's Avatar
Default Re: (elpiar)
Adding water lines drastically increases the coking threashold of the bearings.
Your turbo will run cooler, and it will cool off more slowly.
To answer your question though. Some turbos like the gt series ball bearing turbos, should not be run without the water lines connected.
Other turbos, with journal bearings don't need water cooling as much, but it's still a good idea.
When I first hooked my turbo up (T3 .48/.60) I didn't run the water lines and just left the holes empty. I ran it like that for about a month before I hooked up the water lines. I didn't notice a difference, but I felt better knowing that my turbo was being cooled.
Old Nov 10, 2005 | 09:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elpiar &raquo;</TD></TR><TR><TD CLASS="quote">why not connect it if it's there.
Will help cool down so you dont need a turbo timer that bad unless driving really hard.</TD></TR></TABLE>
More chance for **** to fail when i'm driving, such as those coolant lines popping and less **** to have in my way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">Adding water lines drastically increases the coking threashold of the bearings.
When I first hooked my turbo up (T3 .48/.60) I didn't run the water lines and just left the holes empty. I ran it like that for about a month before I hooked up the water lines. I didn't notice a difference, but I felt better knowing that my turbo was being cooled. </TD></TR></TABLE>
Not quite sure what you mean, the bearings will tend to coke more with water cooling, it will run cooler with water, but take more time to cool off is what you're saying?
Old Nov 10, 2005 | 10:00 AM
EJ1 wilcox's Avatar
Default Re: (O16581724 5 2 5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 &raquo;</TD></TR><TR><TD CLASS="quote">
Not quite sure what you mean, the bearings will tend to coke more with water cooling, it will run cooler with water, but take more time to cool off is what you're saying?</TD></TR></TABLE>
I meant that it will take MORE for the bearings to coke with water cooling (a good thing). And, after you turn the engine off, the water continues to cool the turbo. Cooling the turbo slowly like water does increases the life of the materials used.
Water cooling eliminates the need for a turbo timer because the water will cool the turbo for you.
Sorry, it's hard to explain
Old Nov 10, 2005 | 10:11 AM
JeEvE's Avatar
When running water through the turbo, doesnt that increase the coolant temperature making the car run hotter overall?
Old Nov 10, 2005 | 10:14 AM
Default Re: (EJ1 wilcox)
I got ya, it sounded like you were trying to say what i repeated and that's why it was confusing.
RACEPAK
Feb 13, 2012 01:30 PM
D15Bbigred
Nov 13, 2006 02:01 PM
xx89civicracer89xx
Sep 8, 2006 10:25 AM
intekragsr
Apr 15, 2002 03:58 PM
austrian type-R
Feb 6, 2002 08:23 PM
