chipped P28, CRX climate controls, PG7 ECU, other misc...
two cable D-series starters $15 each (will test them for you)
D-series alternator $5 (tested at 28.98 VOLTS :-X so it needs a regulator)
Z6 motor mount bracket SOLD
88 Civic drivers power mirror $5
15/16 ABS master cylinder $32
factory lightwieght D15 crank pulley SOLD
EF/CRX wiper motor $4
group size 25 battery (good for 90-93 Teg or Accord) one year old $15
B17A1 (B16A) intake manifold and throttle body $50
2 ZC/D16A1 throttle bodies (one with a TPS) SOLD
Accord LXi? throttle body $5
D16A6 cam with gear SOLD
set of B17A1 cams $50
HF/Std/VX cat (perfect inside) $5
SS braided fuel line with billet fuel filter setup for a Honda...$50
not pictured:
chipped P28 $140
88-89 PG7 might be an auto i dont know (will work just fine just throws a code 19 if it is) $40
CRX Climate controls *NOT CRACKED* $75
i can take pics of those later....
located in everett...
Modified by turbohf at 2:38 AM 11/13/2005
JDM-JAMES
Jul 29, 2011 09:13 AM
JDM-JAMES
turbohf
Nov 14, 2005 04:57 PM
cheap ebay stuff, p28 ecu, p75 ecu, b18 tb, ef taillight reflector, crx si intake mani, tb fuel rail
mycvc8u2
Oct 6, 2003 11:15 PM
