Torquing Pressure Plate Bolts
Sup guys,
I was wondering if it's possible to torque down the pressure plate bolts from the starter hole on a D-series motor. What you guys think?
I remember seeing the bolts through the hole I just don't remember if a socket wrench will fit in there or if the bolts were way too low to be torqued. I wanna tighten down the pressure plate a little more and was wondering if I could do it without dropping the tranny.
Writing this, just remember about the flywheel cover on the bottom of the motor. Are the bolts accessible from there? I can't remember seeing them and wanna know if you could.
Thanks!
Thanks!
you dont need to torque anything when i put mine on i just used the impact gun and slammed those suckers on, but yes u can get the swivel sockets to maybe fit in there i just dont think that will still be able to reach all the way because the space is so little
i dont think so because of the location of the pp. even though you take off the starter, a socket wont be able to grab the bolt. you might try using a combination wrench [12pt side of coruse]. or even an offset wrench
Yeah.. If I could only fit the extensions in there that would be no problem I could always increase the torque with an extension in order to torque it in proximity. I just want to tighten the bolts and not torque them at this point.
appelsos
15
May 15, 2013 03:03 PM
crxgurlllll
11
Dec 10, 2002 09:23 AM
