i'm doing a gsr swap in my 96 civic please help me with some question thanks
i got a 96 civic with a 97 gsr swap the motor is in the car already, but my question in order for me to use AC what do i have to do? and how can i run the power steering pump? cause the gsr pump is different from the hose, and for the gas petal cable, can i reuse the one from the car or i need a new cable from 99-00 civic si?
you should be able to get a custom PS hose from somewhere around you that does hydraulics, just bring both hoses and have them make one with the ends you need.
for the throttle cable, we always just fab up a new bracket out of a street sign or something, as long as it doesnt flex you're good.
as for the AC, i have no idea what that even is so sorry i cant help there.
good luck
good luck
I have a 96 civic also that I just swap in with ps and ac. The stock ps unit that came with the civic should work. For the ac, all you need is p54 bracket or you can use the crv bracket same thing but just cheaper. I use the stock gsr throttle cable.
xsuperxsonx
Sep 9, 2010 01:18 PM
