TW: my turbo set up
it is still on the car but over winter I am goin to a bigger set up.
It is a greddy "kit" with 2.5" DP, HKS BOV, all IC piping, and IC. the rubber couplers on the IC are a bit cracked but don't leak so you could use them or not.
If you buy the kit and would want some of my engine managment stuff I will sell that too. I have a hondata 3BD box and Precision 880cc injectors. all you would need is a OBD1 ECU chipped for hondata, 255lph pump, and a tune.
I made 309whp and 242wtq on pump gas with that set up on my car at about 16psi. it spools super fast and is perfect for a daily driver that you want to run low 12's high 11's on street tires. you could go much faster if your car is light since mine is almost 2800lbs with me in it.
I can list vouches if needed.
Modified by BoostR41 at 9:24 PM 11/10/2005
Jason913
Apr 3, 2012 04:17 PM
jp8900
Jul 7, 2006 11:12 AM
BoostR41
Dec 19, 2005 05:40 PM
