Toda valve spring for skunk pro2 ??
Old Nov 8, 2005 | 03:28 PM
jt-sport's Avatar
Default Toda valve spring for skunk pro2 ??
can toda valve springs handle 12.9mm valve lift just like skunk pro stg 2?? anybody have any experience running above 12.7mm valve lift with toda springs??
Old Nov 8, 2005 | 04:57 PM
b19coupe's Avatar
Default Re: Toda valve spring for skunk pro2 ?? (jt-sport)
I ran Toda 'D's with Toda springs and had no problems. 12.9mm advertised intake lift.
Old Nov 10, 2005 | 03:25 PM
jt-sport's Avatar
oww.. only toda spring with out any custom retainers? how high you rev that motor todd??
Old Nov 10, 2005 | 07:10 PM
b19coupe's Avatar
Default Re: (jt-sport)
Portflow retainers. 9,500.
Old Nov 11, 2005 | 12:06 AM
CiSmoEk4's Avatar
im running the toda valvesprings in retainers w/ Skunk Pro 2's in my hatch and revved to 9.2k fine...im sure it could've revved higher though
Old Nov 11, 2005 | 08:33 AM
Black R's Avatar
25 Year Member
i love toda valvesprings.
however, why not run what valvesprings the manufacturer of the cams advertises?
Old Nov 13, 2005 | 05:31 AM
jt-sport's Avatar
Default Re: Toda valve spring for skunk pro2 ?? (CiSmoEk4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiSmoEk4 &raquo;</TD></TR><TR><TD CLASS="quote">im running the toda valvesprings in retainers w/ Skunk Pro 2's in my hatch and revved to 9.2k fine...im sure it could've revved higher though </TD></TR></TABLE>
you mean you use stock retainers??
im not plann to buy another spring because i've already have my toda springs.
Old Nov 16, 2005 | 03:50 PM
CiSmoEk4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jt-sport &raquo;</TD></TR><TR><TD CLASS="quote">
im not plann to buy another spring because i've already have my toda springs.</TD></TR></TABLE>
lol..typing mistake!! i meant toda valvesprings AND retainers...sorry
Old Nov 16, 2005 | 04:09 PM
totsie7944's Avatar
the Toda system is fine with those cams.
Old Nov 16, 2005 | 05:11 PM
rodimus's Avatar
Default Re: Toda valve spring for skunk pro2 ?? (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">i love toda valvesprings.
however, why not run what valvesprings the manufacturer of the cams advertises?</TD></TR></TABLE>
junk2 valvetrain ?
Old Feb 13, 2006 | 08:06 AM
KingOfQB's Avatar
Default Re: Toda valve spring for skunk pro2 ?? (EVOL)
i plan to try stage 3s on the toda
Old Feb 13, 2006 | 09:41 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL &raquo;</TD></TR><TR><TD CLASS="quote">
junk2 valvetrain ? </TD></TR></TABLE>
My point is that some manufacturers will only honor their warranty if the other parts are up to snuff - meaning only their valvetrain with their cams, etc.
Old Jun 12, 2006 | 09:27 AM
SLOW-HONDA's Avatar
jt-sport, would toda springs strong enough with skunk2 pro-series stage 3?
Old Jan 20, 2007 | 05:02 AM
TurtleMax's Avatar
Default Re: Toda valve spring for skunk pro2 ?? (SLOW-HONDA)
been using toda springs with the Pro2..rev it, drag it for bout 6 mth...no problem man.
Old Jan 20, 2007 | 06:54 AM
jdmB18CT-R's Avatar
Toda VS will handle the pro2 and your stock vavles as well
Old Jun 13, 2007 | 09:08 AM
jt-sport's Avatar
Default Re: Toda valve spring for skunk pro2 ?? (KingOfQB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingOfQB &raquo;</TD></TR><TR><TD CLASS="quote">i plan to try stage 3s on the toda</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLOW-HONDA &raquo;</TD></TR><TR><TD CLASS="quote">jt-sport, would toda springs strong enough with skunk2 pro-series stage 3?</TD></TR></TABLE>
i also want to know it......
did toda springs could handle pro serries 3???
or could i just use the pro series springs without the retainer ?? (since i have a bad experience with 'ti' retainer)
Old Jun 13, 2007 | 09:53 AM
LilMrTinnie's Avatar
wow 9.2k? I might have to be looking into this setup. what kind of power is it making to the wheel? This would all run on a stock block right?
Old Jun 13, 2007 | 04:49 PM
DonF's Avatar
or could i just use the pro series springs without the retainer ?? (since i have a bad experience with 'ti' retainer)</TD></TR></TABLE> Stock retainers, or K retainers would have to modified not to hit the seal with these cams. What retainers did you have a problem with? The best avail Valve spring at the moment is the Skunk Pro for the Bseries. I sell all of them, better
Old Jun 13, 2007 | 06:36 PM
jt-sport's Avatar
Default Re: Toda valve spring for skunk pro2 ?? (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote"> Stock retainers, or K retainers would have to modified not to hit the seal with these cams. What retainers did you have a problem with? The best avail Valve spring at the moment is the Skunk Pro for the Bseries. I sell all of them, better </TD></TR></TABLE>
arrrgghh...
you mean the bottom of the retainer should be machined thinner ?? how much (mm) don??
my bad experience in early 2000 is with JG retainer (they claim it was TI, but i think it was alumunium).. 2 of my d series motor blown because their retainer.. thats why i never use aftermarket retainer.
Don, since i never see skunk2 pro series retainer. what is your experience with this pro series retainer?
it doesnt mean i didnt trust skunk2, but im still traumatized with anything related to aftermarket retainer.
thanks don.
Old Jun 13, 2007 | 06:40 PM
jt-sport's Avatar
Default Re: Toda valve spring for skunk pro2 ?? (LilMrTinnie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilMrTinnie &raquo;</TD></TR><TR><TD CLASS="quote">wow 9.2k? I might have to be looking into this setup. what kind of power is it making to the wheel? This would all run on a stock block right? </TD></TR></TABLE>
same here... i run it on the track almost to 9.5K on my stock shortblock ITR (setup was on the bottom of my sig, toda springs+pro2)... the peak was on 9ish-k
and on the dyno, this motor have seen 10.3k several time.. its because we dont watched the tach while we watching the graph climbing when we floor the car on the dyno..
Old Jun 13, 2007 | 11:54 PM
carboy_honda's Avatar
Better use the same manufacturer's product, if i were u.Ti retainers what brand did u use ?
Old Jun 14, 2007 | 05:12 AM
TurtleMax's Avatar
I am using that set-up Pro2 with Toda Springs /Crower Ti retainer....so far no problem at all...daily driven with round 20k miles....
Old Jun 14, 2007 | 05:53 AM
jt-sport's Avatar
Default Re: Toda valve spring for skunk pro2 ?? (TurtleMax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurtleMax &raquo;</TD></TR><TR><TD CLASS="quote">I am using that set-up Pro2 with Toda Springs /Crower Ti retainer....so far no problem at all...daily driven with round 20k miles.... </TD></TR></TABLE>
same as my last ITR setup.
but now im building b20vtec and i plan to go with pro3 camshaft...
thats what im concern about..
im still waiting DonF to hit me back.........
Old Jun 14, 2007 | 06:06 AM
TODAwhore's Avatar
Toda springs are rated to 12.5mm lift...i would check the install heigth and make sure the springs are not going to bind or bottom out. I've seen it happen on motors running D's with it not set up right.
Old Jun 14, 2007 | 06:15 AM
jt-sport's Avatar
Default Re: (carboy_honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carboy_honda &raquo;</TD></TR><TR><TD CLASS="quote"> Better use the same manufacturer's product, if i were u.Ti retainers what brand did u use ?</TD></TR></TABLE>
yep, springs would be pro series... but i dunno about the ti retainer
baysic r
Jun 29, 2009 11:49 PM
KingOfQB
Jan 26, 2006 08:04 PM
JDM97dc2R
Dec 29, 2005 09:15 AM
Slow96RedEk
Jan 15, 2004 04:43 PM
J2turbo21
Jul 25, 2003 06:56 PM
