what did you have to do to install your CAI on your prelude?
does it require any cutting or modification to the body? my friend told me you'd have to cut the body to fit the tube through, as there isn't a big port like on a GSR
ur stock box is already a CAI..just drop in a K&N filter and ull get very similar results..no u dont have to modify anything cept remove the stock air box and the tubing from the CAI will run down under the front bumper cover..most CAI s are a 2 pieces setup so do the top first then set the lower arm in place
