Stock Radio??
Old Nov 8, 2005 | 10:26 AM
chhuong's Avatar
Default Stock Radio??
well i'm selling my car and i went to reinstall the stock radio and only the anti-theft light blinks and the display will not show up its a 2000 integra ls. is the radio shot? or is there some type of procedure i need to do? please help car is being picked up on thursday. thanks in advance
Old Nov 8, 2005 | 10:34 AM
BrooX's Avatar
Default Re: Stock Radio?? (chhuong)
Before you try to hook it back in, are you sure that you have the correct harness?
Old Nov 8, 2005 | 11:17 AM
allmotorgizzles's Avatar
first check all your wiring, and enter the CODE
Old Nov 8, 2005 | 05:10 PM
chhuong's Avatar
Default Re: (allmotorgizzles)
yeah, because i'm using the stock wiring harness, no wires have been cut/removed. just plugged it back in. i do have the code, but the display doesnt show anything.
Old Nov 8, 2005 | 05:24 PM
4dr_all_day's Avatar
Default Re: (chhuong)
its broke
Old Nov 8, 2005 | 05:28 PM
wob's Avatar
wob
hit it with a hammer... if it wasnt broke before then at least u know it is broke after doing so...
Old Nov 8, 2005 | 06:05 PM
chhuong's Avatar
Default Re: (wob)
well don't know if this makes a difference, cuz i just noticed this after doing a search. I noticed that although it's a 2000 it has the older white/gray one piece plug on the radio. did they change the wiring order for this compared to a 92 honda civic? because i got it installed at best buy and i'm wondering if they moved pins around and just used the older harness adapter? anyone have the wiring diagram for the radio for a 99-01 integra?
Old Nov 9, 2005 | 10:56 AM
chhuong's Avatar
anyone got the radio wiring diagram for a 99-01 teg??
Old Nov 9, 2005 | 11:27 AM
JDM-EJ1's Avatar
You will need the radio code for it in order for it to work properly. You can get it from your local dealership.
Old Nov 9, 2005 | 11:37 AM
BrooX's Avatar
Default Re: (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">You will need the radio code for it in order for it to work properly. You can get it from your local dealership.</TD></TR></TABLE>
Try this ^^
onyxsnowfoot
Audio / Security / Video
Mar 12, 2013 11:02 AM
Nooch
13
Aug 19, 2011 04:17 AM
RedHurricane
Jan 31, 2011 09:51 PM
Linh.
23
Dec 6, 2005 10:38 AM
rasta420
May 6, 2002 06:58 AM
