humming noise
Old Nov 8, 2005 | 10:22 AM
int3gra07's Avatar
* B A N N E D *
Default humming noise
I start my car in the morning and at idle, I hear this low humming noise coming from the engine. So I change all my belts. Still the same noise. It only last for about 5 seconds or less. It sounds mechanical though. It only happens once a day at mornings or if car hasn't been started up for a while.
Ive search in here and no one has the same problem. I know what air intake sounds like. And its not the wheel bearings cause I'm not rolling.
This might help: All I have are 421 dc headers k&n short ram and 2 1/4 custom exhaust SPP. and 8 mm magnacor spark wires. ngk spark plugs. Everything else is stock.
Can someone help me out and give me your input?
Thanks.
Old Nov 8, 2005 | 10:34 AM
Hondacrx628's Avatar
Default Re: humming noise (int3gra07)
possibly one of the bearings in the pulleys..
Old Nov 8, 2005 | 10:35 AM
blackdelslo's Avatar
Well if it doesn't do it when its warm then why do you care?
It could be the timing belt is to tight.
Old Nov 8, 2005 | 10:40 AM
int3gra07's Avatar
* B A N N E D *
Default Re: humming noise (delLudeVTEC)
No. it still was sounding like that when all were stock.
Cause its annoying. like you are
ohh BTW I have a g2.
Old Nov 8, 2005 | 11:53 AM
int3gra07's Avatar
* B A N N E D *
Its the first time that I started the car today at lunch time. I opened the hood and didn't hear anything unusual. I guess. I'll start it up tommorrow morning with the hood up and see excactly where its coming from.
Old Nov 8, 2005 | 02:14 PM
Default Re: (int3gra07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Cause its annoying. like you are </TD></TR></TABLE>
ummm k... i gave you a possible solution.
Old Nov 8, 2005 | 02:23 PM
int3gra07's Avatar
* B A N N E D *
just kidding man. I'll check my timing belt out. Thanks.
Pagley
Jan 29, 2011 06:44 PM
professorman
Oct 17, 2008 01:40 PM
Almostlude
Feb 18, 2006 04:26 PM
TypeRCrazy05'
Feb 13, 2005 09:57 AM
