B18c1 install on wiring harness off a b16a2...
Old Nov 8, 2005 | 09:15 AM
JDM00SI's Avatar
Default B18c1 install on wiring harness off a b16a2...
I'm aware of the fact that this is for only hybrid set ups. I'm sure the hybrid crew knows the answer to this question though, might as well place it here.
So i own a 2000 SI, and obviously the wiring harness is for a b16a2. We are currently dropping in a GSR engine. I heard tthe wiring harness had to be modified in order to do this. What needs to be modified?
Thanks
Old Nov 8, 2005 | 09:17 AM
JDM00SI's Avatar
dont flame me for posting this in the hybrid section. i figured that since this is a swap section, you guys should know.
Old Nov 8, 2005 | 08:05 PM
JDM00SI's Avatar
Default Re: B18c1 install on wiring harness off a b16a2... (JDM00SI)
k thanks for the good help guys, i really expected more, but whatever.
Old Nov 8, 2005 | 11:42 PM
Supernatural's Avatar
what year gsr?
Old Nov 9, 2005 | 09:17 AM
JDM00SI's Avatar
Default Re: B18c1 install on wiring harness off a b16a2... (NATURAL)
well its being dropped into a 2000 SI, i dont think the year of the gsr motor matters....... If it does..ill look into the year of the block.
Old Nov 9, 2005 | 10:24 AM
jdmitr's Avatar
It does if you are planning on keeping it OBDIIb. 94/95 B18c1's don't have crank position sensor down by the lower timing belt gear. If you are planning on keeping the GSR intake mani then you will have to move a few sensor plugs, and you will have to wire up the IAB to control the secondary butterflies. If you have a OBDI B18 then you will need to use your injectors (OBD I plugs are different), and the GSR FPR. Also your dist plug will be different as to which OBD. I would get a different manifold like a S2 etc... Also if you have a pre 98 (I beleive) your exhaust won't fit. The down pipe on the pre 98's are very short.
Old Nov 9, 2005 | 05:10 PM
JDM00SI's Avatar
it is converted to obd1...i will be using 100 percent after market parts....
Old Nov 9, 2005 | 10:41 PM
WhiteNess's Avatar
Default Re: (JDM00SI)
If you use the GSR intake manifold then you gotta wire up the secondaries by hand. You don't have to splice the IAT sensor just use the same Intake your currently using and you will be fine. Not manifold...but intake.
My friend did the same swap and he threw code 54....and to this day I can't figure out why. We checked everything like 10 times and everything was fine. Any clues anyone?
Are you going to use ur 00 Si computer? or you gonna use a GSR computer?
Old Nov 10, 2005 | 04:36 AM
JDM00SI's Avatar
p28 chipped hondata s200 w/ boost. i will not have an intake because it will be booosted. i will be using a edelbrrock intake manifold.
obd1 obviously
Old Nov 10, 2005 | 05:53 AM
JDM00SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM00SI &raquo;</TD></TR><TR><TD CLASS="quote">p28 chipped hondata s200 w/ boost. i will not have an intake because it will be booosted. i will be using a edelbrrock intake manifold.
obd1 obviously</TD></TR></TABLE>
Old Nov 10, 2005 | 07:59 AM
jdmitr's Avatar
Then it will be pretty straight forward.
Old Nov 10, 2005 | 09:08 AM
JDM00SI's Avatar
oh ok. Thanks for advice. Also when it comes ti wiring it up, what are techniques you guys use to keep the wiring harness away from the engine to prevent it from melting or starting a fire? Are there clips or something that clip the wires to the firewall or chassis of the car? Thanks
guy_from_nerk
Jan 23, 2010 07:50 PM
mstewar
Dec 18, 2003 08:26 AM
