clutch? what one to get
Old Mar 9, 2002 | 09:49 PM
tdc's Avatar
tdc
Default clutch? what one to get
well my clutch is slipping a little when i rev it out and grab a gear so... i looked up a few on the net.. and there like 4-500 bucks if i put a stock si clutch in will i have trouble with a zc motor later like how good should i go ? it`s not like i`m power shifting every day..
Old Mar 10, 2002 | 02:26 AM
carsaregood's Avatar
Default Re: clutch? what one to get (tdc)
I have an ACT hybrid street disc (supposed to be hybrid lining good for high rpm launches) with their heavy duty pressure plate (212mm). And damn, i like it quite a bit. It bites way better than a stock clutch. the pedal is a little bit harder to press in, but you get used to it really quickly. I've driven a turbo zc powered CRX that had a ridiculously hard clutch, so comparatively, i'm really happy with it. On top of it all, the torque capacity of the kit is 223 lb. ft... so that even gives me room for a turbo...
Old Mar 10, 2002 | 07:14 AM
Denny317's Avatar
Get the ACT Street clutch...I had it on my ZC and it worked great.
88backhatch
Oct 13, 2005 05:12 PM
therealciviczc
Jan 31, 2002 06:06 PM
