knocking/pinging sound in my b16 ek hatch! Help Please!
Old Nov 7, 2005 | 11:26 PM
zerogravitycrx's Avatar
Default knocking/pinging sound in my b16 ek hatch! Help Please!
at start up there's a knocking/pinging sound in my b16, then quits after a few seconds! and at idle at driving at 3500 rpms it makes the same sound but quite though! i added engine oil 10-30wt, because it was low and was flashing in my gauge cluster! and still makes noise at start up and driving.
do you know what it could be?
Old Nov 7, 2005 | 11:31 PM
SOHC4life 96's Avatar
Default Re: knocking/pinging sound in my b16 ek hatch! Help Please! (zerogravitycrx)
Your oil light was coming on? You probably spun a rod bearing. Is it a really loud knocking noise? If it is, then time for a rebuild/new engine.
Old Nov 7, 2005 | 11:33 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerogravitycrx &raquo;</TD></TR><TR><TD CLASS="quote">do you know what it could be? </TD></TR></TABLE>
Stupidity.
Does it knock all throughout the powerband?
Old Nov 7, 2005 | 11:44 PM
Default Re: knocking/pinging sound in my b16 ek hatch! Help Please! (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">Your oil light was coming on? You probably spun a rod bearing. Is it a really loud knocking noise? If it is, then time for a rebuild/new engine.</TD></TR></TABLE>
i just notice it last friday, and never drove it since today! its not real loud, just at start up and then quits! does make a pinging sound when driving over 3500rpm's in any gear, and doesnt make a sound when driving under 3500rpm's! the pinging noise is likely coming from behind the head, (intake manifold side)! it must be the oil! the dipstick didn't indicate any oil on it! but when i topped it off its good! but still has that pinging sound! it a fresh rebuilt engine with now 2k miles on it!
Old Nov 7, 2005 | 11:48 PM
Luserkid's Avatar
it was a fresh rebuilt engine with now 2k miles on it! </TD></TR></TABLE>
fixed that for you. Who knows you might be able to save it but i wouldnt hold my breath.
Old Nov 8, 2005 | 05:48 AM
96 EX's Avatar
Default Re: knocking/pinging sound in my b16 ek hatch! Help Please! (Luserkid)
my y8 did that **** tore it apart throw a bearing and the rod chewed that **** up from hell and back also clogged my oil filter and put metal shavings in my oil pan and filter. better check that **** out mine was also a week after i noticed the knocking when it went out.
jdmstyleg
Sep 8, 2009 04:30 PM
(760)doogie
Apr 27, 2008 01:49 PM
Crab Man
May 22, 2007 03:43 PM
my92hondasucks
Jan 16, 2006 12:48 PM
prettysweetcivic
16
Oct 22, 2004 05:50 AM
