Where can I find this information...
Hey guys im new to this site i uset to be a 91 EF owner which recently i have departed so i came here cause i own a 95 Itegra LS and its completely bone stock even the original tape deck is in it 136,000 miles on her and in great condition.
Anyways im no expert gear head but im learning and the only way to learn would be to ask so here goes nothing...
Where can i find instructions or how to do a complete JDM front end conversion? Like what modifications do I have to make or any alterations to the body etc..
Also where can I find instructions how to wire a B18C1 or C5 and completely install it into the car once it was takin out out. Just curious what I have to hook up and disconnect and where every wire goes and such.
I would be really happy and I would appreciate all your help but im just trying to understand this stuff and gain knowledge. If you could please help me in any way Thank You for reading.......
the search feature will be your new best friend. There are a thousand threads about the JDM front. Really it is a bolt on, apart from the fact you have to weld the radiator support back in, but everything else bolts up.
If you really want to swap the motors I would also swap out the wiring harness, that way you know everything will match up and work. I know i have seen some write ups here on HT about running wires from different sensors to the ECU.
DJNauTicz
13
Apr 7, 2007 10:11 PM
