surging at idle help
Old Nov 7, 2005 | 08:39 PM
jgt8229's Avatar
Default surging at idle help
my mom has a 1989 accored se-i. sometimes it wil just randomly surging like the idle, like it idles then revvs up to like 2000rpm then drops back down to idle, then repeates this right after it gets back down to idle. it does it for like 5 minutes then stops and it will idle normal. could the iac just be dirty? i rember seeing a thread on how to remove the iac and everything from the throttlebody but i cant find it, it had pictchures and everything, can someone tell me what the problem is or if the iac senser if jus dirty, and give me the link to that thread if they have it
Old Nov 7, 2005 | 09:30 PM
momstaxi's Avatar
Default Re: surging at idle help (jgt8229)
most likley the cause is actually the fast idle thermo valve, or fitv.
with as many questions about it and idle problems they should make this link a sticky or something.
https://honda-tech.com/zerothread?id=699787
all honda fitv are all pretty similar so this should work
Old Nov 8, 2005 | 02:45 AM
P_Adams's Avatar
Default Re: surging at idle help (momstaxi)
Does that mean he's got an "iffy" Fitv???
P
What do you expect at 06:45am, Jeff Foxworthy?
Old Nov 8, 2005 | 03:45 AM
Hondaman56's Avatar
From: Filthadelphia City of Brothers and Love, PA, USA
Is it cold now where you live? If so, this is caused by a stuck open thermostat. Happened to me and took me two years to figure out.
Old Nov 8, 2005 | 05:11 AM
deserthonda's Avatar
remove the top cover of the fast idle valve, 2 phillip screws, tighten the inner valve, reinstall cover, post results..
simon.vada
Sep 23, 2018 04:42 PM
Run Away
Mar 11, 2006 05:08 PM
