Suspension & Brakes Theory, alignment, spring rates....
Are my springs adjustable?
Old Nov 7, 2005 | 06:50 PM
mikeunreal's Avatar
Default Are my springs adjustable?
I dont know if my springs are adjustable or not. They have 2 ring looking things on them, and there on some spiral looking part of my shock. Does this mean i can adjust them??
Mike
Old Nov 7, 2005 | 07:17 PM
CRX Lee's Avatar
Default Re: Are my springs adjustable? (mikeunreal)
Your description isn't working for me. Can you take a photo? Does it look like a stock system with a fixed perch or a coil-over threaded system?
Old Nov 7, 2005 | 07:20 PM
mikeunreal's Avatar
Default Re: Are my springs adjustable? (CRX Lee)
It looks like some kind of spiral toward the middle of my shock....
Old Nov 7, 2005 | 07:21 PM
CRX Lee's Avatar
What is spiral....the spring itself or the part of the shock where the spring perch is?
Old Nov 7, 2005 | 07:23 PM
mikeunreal's Avatar
i dont know what the spring perch is...
The spring stops on some metal ring looking thing which is at the spiral part of the shock. It looks like i should be able to unscrew it and raise it down to allow more spring travel? i dont know tho
Old Nov 7, 2005 | 07:24 PM
PIC Performance's Avatar
I'm guessing he means threads?
Like this?
If so, it would appear that you have an adjustable spring perch.
Old Nov 7, 2005 | 07:26 PM
mikeunreal's Avatar
Default Re: Are my springs adjustable? (PIC Performance)
ya it looks like a spring would be on top of that...
My problem is my spring is REALLY compressed.. and i have no suspension travel at all. so when i hit bumps and **** its slamming and ruining my ****
Old Nov 7, 2005 | 07:31 PM
So at regular ride height, is your spring already fully compressed/somewhat close to it?
If thats the case you might just have the perches too high and lowering them would help. But your car would also be sitting very high in that case I think...
Old Nov 7, 2005 | 07:33 PM
mikeunreal's Avatar
no no my **** sits like i wana say 3 inches or so low...
my tires are right under my wheel well
Old Nov 7, 2005 | 07:44 PM
gsrious's Avatar
just turn the spring perch upwards to raise your ride height.
Old Nov 7, 2005 | 07:46 PM
mikeunreal's Avatar
Default Re: Are my springs adjustable? (gsrious)
so screw it so it goes down closer to the bottom of the shock?? so my spring streches out longer..
Old Nov 7, 2005 | 08:02 PM
In that case, I'd say your springs have sagged beyond the point of being useful, and you should looking into new springs.
Old Nov 7, 2005 | 08:23 PM
mikeunreal's Avatar
no i was asking if i can screw the perch and raise up my springs providing me with more spring travel. woudl that help or are my springs shot....
Mike
Old Nov 7, 2005 | 10:41 PM
Tyson's Avatar
if im understanding you correctly, if anything, screwing the perch up would make things worse and not give you any more SPRING travel. however, it may give you more SHOCK travel, which i think you might be confusing terms here...
is there not a lot of space between the coils of the spring?(spring travel) or is there not a lot of space between the top of the shock and the top of the shock rod?(shock travel)
Old Nov 8, 2005 | 03:36 AM
mikeunreal's Avatar
Default Re: Are my springs adjustable? (Tyson)
is is unscrewing the perch toward the bottom of the perch closer to my wheel gona make it worse...isnt that allowing the spring to expand giving me more spring travel...
Old Nov 8, 2005 | 05:19 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal &raquo;</TD></TR><TR><TD CLASS="quote">is is unscrewing the perch toward the bottom of the perch closer to my wheel gona make it worse</TD></TR></TABLE>
Yes, it will make the car lower and decrease your shock travel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal &raquo;</TD></TR><TR><TD CLASS="quote">isnt that allowing the spring to expand giving me more spring travel...</TD></TR></TABLE>
The spring will compress to the same length based on the weight of the car and the springrate. It sounds like you may have either poor quality springs that have 'sagged' and are no longer useful; or they were very low rates and the collar had do be raised very high to get the car at an acceptable ride height, and it compressed the spring down. It could also be a combination of the two problems.
Old Nov 8, 2005 | 04:20 PM
mikeunreal's Avatar
Default Re: Are my springs adjustable? (AutoXer)
do you guys think that i still have shocks left??? i guess since the springs were so compressed its not really using the shocks that much...
Old Nov 8, 2005 | 04:23 PM
Tyson's Avatar
please take a picture. i cant tell if its a communication issue or a technical issue.
Old Nov 8, 2005 | 04:31 PM
mikeunreal's Avatar
ok, where can i host the picture at??
Old Nov 8, 2005 | 04:37 PM
I use Photobucket.com, really really good service. Recently they put a cap on image sizes I think, but I get around it by converting to GIF's.
Old Nov 8, 2005 | 04:51 PM
mikeunreal's Avatar
stupid camera gata be all not working and stuff.... god i hate this ******* camera...
Old Nov 8, 2005 | 04:55 PM
Don't have a camera phone? It seems like everyone's phone's got a camera these days.
Old Nov 8, 2005 | 04:58 PM
mikeunreal's Avatar
Old Nov 8, 2005 | 05:04 PM
Tyson's Avatar
yeah, your springs are near coil binding.
lowering the perch wont actually do anything positive for you.
is there any writing on the springs?
the sleeves LOOK like ground controls sleeves, but ive seen exact look alikes of ground control sleeves. and those springs i am almost positive are not eibachs. and it could be possible someone swapped springs with the orignal ground control sleeves.
so tell us whats written on the spring and gold perch, if anything.
Old Nov 8, 2005 | 05:06 PM
mikeunreal's Avatar
k brb leme look.... i think there crappy springs...
