4th gen Manual Parts for 5th Gen?
Old Nov 7, 2005 | 05:46 PM
Yuleluder's Avatar
Default 4th gen Manual Parts for 5th Gen?
I have a specfic question about the half shaft from a manual 92 prelude SI. Is this half shaft the same as the 5th gen manual half shaft? Or better yet can one use the parts from a 92 Prelude SI to do a auto to manual conversion on a 5th gen Prelude?
Old Nov 7, 2005 | 06:15 PM
K-Spec's Avatar
Default Re: 4th gen Manual Parts for 5th Gen? (Yuleluder)
you will need a 5th gen half shaft and a 5th gen tranny mount
Old Nov 11, 2005 | 05:45 AM
Yuleluder's Avatar
Default Re: 4th gen Manual Parts for 5th Gen? (khalal538)
I found this on one of your previous posts
"I did my own manual swap...if you don't believe me...call HONDA and ask them if the 4th gen shifter assmbly is the same as the 5th gen, they will give you different part numbers. Trust me, i'll tell you what is interchangeable...and there aren't a lot of parts that are."
I am getting a 93-96 h22a JDM front clip with LSD Tranny. From my research I have found that I will need the Half Axle from a 5th gen and the 5th gen manual tranny mount. Now I read one of your previous posts and it seems I need a couple other 5th gen parts. Is this correct?
Old Nov 11, 2005 | 09:46 AM
K-Spec's Avatar
yes, you will need the clutch hard line...unless you can find a shop that can fabricate a steel braided one. You will also need a 5th gen shifter assembly and cables. I would recommend purchasing a LEANRacing.com short shifter since it'll save you money because it comes with the whole assembly. I would try to get new shift cables just because sometimes the old ones that you find from a junkyard don't work that well because they have lost the lubrication inside. From what I can remember, those are the parts that aren't interchangeable, everything else should work.
Preferio
Sep 25, 2006 04:46 PM
reco2rip
May 16, 2004 05:14 AM
CloudDragon
Jun 26, 2002 06:43 PM
