Suspension & Brakes Theory, alignment, spring rates....
camber kit necessary?
Old Nov 7, 2005 | 05:39 PM
alacard's Avatar
Default camber kit necessary?
so i just put on the koni/gc shock/coilover combo...i lowered it a decent amount, and put on some brand new rims and tires...so i had been putting off getting it aligned...and i finally went in today...and the guy said there was no way for them to adjust the camber on the wheels...is this true?...he said i would HAVE to get a camber kit...i didnt know that a camber kit was necessary....if it is...can someone point me in the right direction on what i would need to do?..is this all i need?:
https://honda-tech.com/zerothread?id=1179927
also...if i got the camber kit, would i even need to take it to get it aligned...or is it possible to diy?
thanks in advance
Old Nov 7, 2005 | 06:14 PM
Joon Joon's Avatar
Default Re: camber kit necessary? (alacard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">so i just put on the koni/gc shock/coilover combo...i lowered it a decent amount, and put on some brand new rims and tires...so i had been putting off getting it aligned...and i finally went in today...and the guy said there was no way for them to adjust the camber on the wheels...is this true?...he said i would HAVE to get a camber kit...i didnt know that a camber kit was necessary....if it is...can someone point me in the right direction on what i would need to do?..is this all i need?:
thanks in advance</TD></TR></TABLE>
u dont need a camber kit.. just get the toe zeroed out... if u lower or raise ur car then ur gonna have to get the car aligned again
Old Nov 8, 2005 | 02:46 PM
alacard's Avatar
but i can even see the camber in the back..its way off...the tire looks more like this: /
instead of like this: |
wont that completely wear out the tire on the inside?
Old Nov 8, 2005 | 05:32 PM
fast hatch's Avatar
it would wear your tires out pretty quick but they still can align it. it may not be dead on but they should be able to get it close enough. thats what i did i rotate my tires like once a month and im aight.
Old Nov 8, 2005 | 09:35 PM
alacard's Avatar
Default Re: camber kit necessary? (fast hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast hatch &raquo;</TD></TR><TR><TD CLASS="quote">it would wear your tires out pretty quick but they still can align it. it may not be dead on but they should be able to get it close enough. thats what i did i rotate my tires like once a month and im aight. </TD></TR></TABLE>
hmm...yeah...the guy said they can adjust the toe but not camber...because the car just doesnt have anything to adjust it with (unless i buy a kit)....so i guess its a matter of paying now for the kit...or paying later (or sooner than later) for tires.
Old Nov 8, 2005 | 10:28 PM
94eg!'s Avatar
#1 Super Guy
Loved
Even though you can see the negative camber, it still won't cause premature tire wear. Poor toe settings, however, will cause the cambered edge to wear excesivly fast. Get the toe set to zero and you should be pleasently surprised just how long your tires can last.
my 94 CX is lowered 2.5-3" and I got almost 50k miles on my Euro TA (340 treadwear). No camber kits & only 2 tire rotations...
Old Nov 9, 2005 | 03:39 AM
ecahatch's Avatar
Senor Miembro
Default Re: camber kit necessary? (94eg!)
time for me to get an alignment, Mr. Tire, Midas, etc good enough?
Old Nov 9, 2005 | 09:49 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: camber kit necessary? (ECAhatch)
Should be...
Old Nov 9, 2005 | 02:17 PM
alacard's Avatar
thanks for the replies...ill go ahead and stop by the shop again...but just out of curiousity...what exactly is the benefit of having zero camber?..or is there none?
Old Nov 9, 2005 | 02:22 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (alacard)
Increased outter tire wear from "spirited" driving... LOL!
Really it provides greater traction for braking & acceleration, but thats about it (but even thats debatable with dive & squat geometry). Zero camber would be ideal for drag racing & grandma drivers...
Old Nov 16, 2005 | 04:18 PM
alacard's Avatar
sorry to bring this back up again...but i went back to get the alignment done...and the guy insisted that i should really get a camber kit, he said it would wear out my tires like crazy...i called some people and eventually decided just to get the alignment done without camber or caster adjusted...the guy says if i bring it back within a month with the camber kit on, they wont charge for another alignment...so WHATS THE DEAL...some people say it will wear my tires out, other say it wont...i dont know what to go with.
Old Nov 16, 2005 | 04:35 PM
dc4g's Avatar
Camber kit will help but its not needed, Do the washer trick on the back.
Negative camber performs better anyway
Old Nov 16, 2005 | 05:31 PM
alacard's Avatar
Default Re: (dc4g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc4g &raquo;</TD></TR><TR><TD CLASS="quote">Camber kit will help but its not needed, Do the washer trick on the back.
Negative camber performs better anyway </TD></TR></TABLE>
hmmm, whats the washer trick?
Old Nov 16, 2005 | 08:10 PM
dc4g's Avatar
it fixes the camber in the rear, There are bolts that hold the uca in the rear on just buy high grade bolts that are longer and place washers in behind the bracket repeat untill desired camber angle is acheived. then get it aligned.
Try searching.
Old Nov 18, 2005 | 09:20 PM
AftermarketCarl's Avatar
The toe setting is most important.
I've run camber correction kits in all of my cars and have had awesome results when it came to tire wear, along with propper tire pressure and consitent tire rotations.
If the majority of you driving is done on the highway and surface streets I would suggest having camber correction kits installed and set up propperly. What has worked for me is to have as much camber taken out of the rear as possible without having the outside of my tires rub on the fender. I leave at least one degree of negative camber in the front for better turn in. Also, if you take out all of the negative in the front, your car will follow every contour of the road and that's no fun. Make sure that your toe settings are set up as close to factory specs as possible.
Old Nov 20, 2005 | 07:48 PM
lazybrown187's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch &raquo;</TD></TR><TR><TD CLASS="quote"> time for me to get an alignment, Mr. Tire, Midas, etc good enough?</TD></TR></TABLE> I 2ND THIS GUY
Old Nov 21, 2005 | 06:57 PM
Zeus Zore's Avatar
Default Re: (dc4g)
yea.. depends what you are using the car for...
negativ camber effect break lenght and straight line driving and others...
but yes in a hard corner it will be better... but most peep dont use that..
Old Nov 21, 2005 | 08:41 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">sorry to bring this back up again...but i went back to get the alignment done...and the guy insisted that i should really get a camber kit, he said it would wear out my tires like crazy...i called some people and eventually decided just to get the alignment done without camber or caster adjusted...the guy says if i bring it back within a month with the camber kit on, they wont charge for another alignment...so WHATS THE DEAL...some people say it will wear my tires out, other say it wont...i dont know what to go with.</TD></TR></TABLE>
won't wear "like crazy." will wear slightly faster on the inside, and by slightly i mean really really slightly.
what are your current camber settings? if they're less than -3 degrees (meaning something like -2, -1.5, -2.3) i wouldn't worry about the camber kit.
camber kits are nice to have, but not to save tires--just for suspension tuning purposes. once again, unless you've got insane camber settings, just zero out the toe.
Old Nov 27, 2005 | 07:41 PM
rafael_dias's Avatar
how bout my suspension setup?
Rear:
Camber: before/after
L: -2.29 / -2.37
R: -2.48 / -3.08
Toe: before/after
L: - 0.1mm / +2.0mm
R: +2.2mm / +2.0mm
Front:
L: -2.17 / -2.19
R: -1.56 / -2.05
Toe: before/after
L: -2.5mm / +2.1mm
R: -0.3mm / +1.9mm
Is this a good wheel alignment?
Old Nov 27, 2005 | 09:03 PM
MattD@Stoptech's Avatar
Default Re: (TP9)
Nope, it's horrible, why so much toe front and back?
Old Nov 27, 2005 | 10:34 PM
hmm thats strange, he works for a reputable performance shop...
what should i recommend he do?
Old Nov 28, 2005 | 04:31 AM
Zeus Zore's Avatar
Default Re: (TP9)
you have abit 2 much diffrens in camber on the rear.. (somthing needs change or something is bent
and if it is a EG i would go about 0 front and 0 to like max -0,5 degree in the back
civic_saints1
Suspension & Brakes
Jul 27, 2007 01:59 PM
bryandamatrix
Jul 18, 2004 01:00 AM
Bigtymr1
Apr 17, 2004 11:20 AM
i3luemrld
Feb 6, 2004 11:44 AM
E-lude78
11
Oct 20, 2003 07:21 PM
