1999 Accord EX 4 DR 2.3 VTEC 4 Cylinder Oil in Coolant`
Old Nov 7, 2005 | 03:18 PM
cruzer_usa's Avatar
Default 1999 Accord EX 4 DR 2.3 VTEC 4 Cylinder Oil in Coolant`
Can anyone give me an idea on why my car has oil in the coolant but none in the engine coolant in the oil. My coolant reservoir is full of oil but the engine oil is clean. The car still runs fine. Any help would be great. Thanks
Old Nov 7, 2005 | 03:32 PM
P_Adams's Avatar
Default Re: 1999 Accord EX 4 DR 2.3 VTEC 4 Cylinder Oil in Coolant` (cruzer_usa)
What you're dealing with is a transferance of fluids from one pressurized system (oiling @ 55-65psi) to another (cooling @ 18psi). The trick is trying to locate it. The unfortunate part is that the only common point between the two is the engine block/assembly.
There was one thread in here previously which spoke of a similar problem which was determined to be a threaded bore for one of the head bolts which was drilled too deep.
In reality, there are only two areas in which this could happen:
1) Engine Oil / Coolant: .......... Engine Block / Head
2) Trans Fluid / Coolant: ......... Trans Fluid Cooler in Radiator
A coolant system pressure test (of a protracted length) may confirm an internal leak. Addressing it is another matter.
P
Old Nov 7, 2005 | 06:06 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: 1999 Accord EX 4 DR 2.3 VTEC 4 Cylinder Oil in Coolant` (P_Adams)
possible head gasket??? But that would put coolant in the oil....
Old Nov 7, 2005 | 07:56 PM
P_Adams's Avatar
Default Re: 1999 Accord EX 4 DR 2.3 VTEC 4 Cylinder Oil in Coolant` (Vt4cPwn35)
But ask, why not? It's in the same area as the ill-machined threaded head bolt hole. What makes it difficult is that there are no classic symptoms of a blown head gasket. IE:
1) Steam from exhaust
2) Dead Cylinders
3) And the always obligatory Coolant in the Crankcase.
To make matters worst, The traditional Compression and Leak-Down Tests will be inconclusive. We're going to have to rely on a protracted Coolant Pressure Test to tattle on any interior maladies.
P
jpusser
Jun 4, 2012 12:31 AM
monkfe
Jan 13, 2010 04:55 AM
bluecivic107
Feb 13, 2008 11:21 AM
redbox
Feb 28, 2006 07:16 AM
First Honda 1976
Apr 23, 2004 03:22 PM
