BRAKE NIPPLE LEAKING HELP
Old Nov 7, 2005 | 01:45 PM
Pnoyej6's Avatar
* B A N N E D *
Default BRAKE NIPPLE LEAKING HELP
My bro has a leak on his 99 civic with b18b swap. It is leaking brake fluid on the brake nipple, where the front passengers brakes are located. What could be the problem? He bled the brake couple weeks ago.
Old Nov 7, 2005 | 02:09 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: BRAKE NIPPLE LEAKING HELP (pnoytegn707)
Is the bleeder tight? Otherwise, there could be debris on the bleeder seat.
Old Nov 7, 2005 | 02:15 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: BRAKE NIPPLE LEAKING HELP (Dogginator)
YES HE TIGHTEN IT .
Old Nov 7, 2005 | 02:16 PM
Pnoyej6's Avatar
* B A N N E D *
WHAT KIND OF LIQUID GASKET CAN I USE? RTV SEALANT?
Old Nov 7, 2005 | 02:27 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pnoytegn707 &raquo;</TD></TR><TR><TD CLASS="quote">WHAT KIND OF LIQUID GASKET CAN I USE? RTV SEALANT?</TD></TR></TABLE>
TURN OFF THE CAPS LOCK.
Liquid gasket will not withstand the pressure in the brake system. He may need to remove the bleeder and check for debris at the seat. Do not hit the brake pedal with the bleeder removed.
Old Nov 7, 2005 | 02:40 PM
Pnoyej6's Avatar
* B A N N E D *
What sealant will withstand the pressure?
Old Nov 7, 2005 | 02:44 PM
Dogginator's Avatar
Daisy... Daisy...
You need to fix the problem with the bleeder. You are not going to find a sealant that will work. The worst case scenario will require replacement of the caliper.
nicky352
Dec 15, 2010 07:32 AM
Donhonda84
May 7, 2007 07:50 PM
CivicHP
Sep 30, 2005 01:32 PM
udm_motorsport
Mar 10, 2004 06:17 AM
viperguy
Jul 29, 2003 06:57 PM
