More b18b swap questions
Old Nov 7, 2005 | 12:26 PM
Gr0c3ryG3tt3r's Avatar
Default More b18b swap questions
Sorry to rattle everyones brains...but can I swap a 94 b18b into a 98 civic ex? If I can, can I use the same wiring harness? Also will parts from the b18a swap to the b18b? (ex. pistons, rods, etc....)
Thank you ahead for your inputs!
Old Nov 7, 2005 | 01:01 PM
o5mar1's Avatar
yes b18a and b18b parts are intercheable and im preaty sure you can use the harnes/
Old Nov 7, 2005 | 03:46 PM
Default Re: (o5mar1)
So the 94 B18b can be used in my 98 civic? I live in CA, might this be a problem?
Old Nov 7, 2005 | 04:05 PM
Andres-eh2's Avatar
From what ive read on here, in Cali cars cant have swaped engines unless its the same year as the car or newer.
Old Nov 7, 2005 | 06:15 PM
o5mar1's Avatar
in that case your going to need a b18b head, the smog tech's usually dont know anything about hondas so as long as the head says 98 youl get away with it oh and have the ecu of the a 98 integ
Old Nov 7, 2005 | 06:16 PM
o5mar1's Avatar
i meant a 98 year cylinder head
Old Nov 7, 2005 | 06:22 PM
freakin_eLRoD's Avatar
not to mention he'll need the ckp sensor otherwise he'll throw up a check engine light for that, not to mention if it is a dx/cx civic he'll have to rewire the iacv and there is a good write up on it here some place
wpgcivic
Nov 21, 2004 08:26 AM
jman30513
Jul 16, 2004 10:11 AM
Halo
Nov 20, 2001 07:44 PM
