Prelude injectors swap
Old Nov 7, 2005 | 12:22 PM
victorpapa's Avatar
Default Prelude injectors swap
Somebody tried to swap the Prelude 5th gen. injectors on a itr?
Is it true they are 290cc saturated like the jdm ITR and the usdm and eudm are 240cc?
It is a good upgrade?
Old Nov 7, 2005 | 01:27 PM
Eva01's Avatar
Default Re: Prelude injectors swap (victorpapa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by victorpapa &raquo;</TD></TR><TR><TD CLASS="quote">Somebody tried to swap the Prelude 5th gen. injectors on a itr?</TD></TR></TABLE>
Yes people have done this. I currently run them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by victorpapa &raquo;</TD></TR><TR><TD CLASS="quote">Is it true they are 290cc saturated like the jdm ITR and the usdm and eudm are 240cc?</TD></TR></TABLE>
Yes they flow 290cc. JDM ITR injectors are 240cc just like USDM and EUDM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by victorpapa &raquo;</TD></TR><TR><TD CLASS="quote">It is a good upgrade? </TD></TR></TABLE>
Possibly but it's impossible to tell without knowing what your fuel needs are. They will require fuel tuning. I suggest you try searching the archives for more information.
Modified by Eva01 at 7:35 PM 11/7/2005
Old Nov 7, 2005 | 10:33 PM
victorpapa's Avatar
Default Re: Prelude injectors swap (Eva01)
Thank you very much Eva
I read in the faq they are plug&play.
At the moment I have only the stock ecu modified by Erade ( jdm conversion) and a fuel pressure regulator (max fuel pressure 60 psi).
Could I swap in this condition?
Old Nov 8, 2005 | 04:21 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by victorpapa &raquo;</TD></TR><TR><TD CLASS="quote">...I have only the stock ecu modified by Erade ( jdm conversion) and a fuel pressure regulator (max fuel pressure 60 psi).
Could I swap in this condition?</TD></TR></TABLE>
You could, sure, but you might be swapping with a view to the future instead of with a view to actually needing them right now.
Unless your modified ECU is aggressive with the spark advance and fuel delivery, and/or you are looking at tuning the cams, it's possible that you really aren't going to be getting the maximum benefit.
I have those injectors in my car, but I also have a Hondata, slightly raised compression, worked head and other improvements.
Old Nov 8, 2005 | 04:27 AM
Eva01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by victorpapa &raquo;</TD></TR><TR><TD CLASS="quote">Thank you very much Eva
That is correct, the 97+ prelude injectors are plug&play. However, based on the information you provided, I still don't have a complete picture on what your fuel needs are. In other words, what engine modifications justify running your fuel pressure at 60 psi? Has your car been tuned on the dyno? More info please.
Old Nov 8, 2005 | 05:08 AM
D's Avatar
D
seriously guys... 240's on a stock motor will see above 90% duty cycle. there isn't much of a reason not to use 290's and go from there.
Is that a complete enough picture?
Old Nov 8, 2005 | 05:14 AM
H-T Order of Merit
Default Re: Prelude injectors swap (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">Is that a complete enough picture?</TD></TR></TABLE>
Yes. Thank you for debunking the apocryphal information.
Old Nov 8, 2005 | 05:43 AM
SecretAgent's Avatar
i'm willing to bet that your car is running severly rich as it is with the stock injectors and that fuel pressure. even on my lightly modded motor, i had to cut the duty cycle back on the JDM ecu heavily to get to the 13.2-13.4 target a/f ratio at wot. i'm running stock 240cc injectors and stock fuel pressure.
Old Nov 8, 2005 | 12:24 PM
victorpapa's Avatar
Default Re: (SecretAgent)
I run a Spoon b18c-r engine 11.5:1 cr and my complete engine setup is:
ENGINE:
Spoon B18C ‘98 spec R Engine n.3604789
Erade Ecu Jdm conversion
NKK 6 Sprungs hub organic disc clutch + 1350 lbs pressure plate clamp load
Ice Box Comptech + Comptech filter element
AEBS Typhoon intake manifold
B&M Adjustable fuel pressure regulator at 60 psi
B&M Fuel pressure gauge
Hondata intake manifold gasket
Ported throttle body
Throttle body heathing by-pass
Low Temp. Mugen Thermostat
Mugen Switch fan
Spoon radiator cap
RMF Narrow b18 header 2.5”
Custom SS B-pipe 2,5”id
2.5” flex test pipe
Apexi N1 Muffler Exhaust- 60mm
Apexi sparks wire (NGK powercable)
DENSO Iridium Spark Plug Plugs - IK24
Energysuspension motor mount
Oil Catch Tank Weapon R
Olio Motul 8100 0W40 (winter) Mobil 1 5W50 (summer)
Old Nov 8, 2005 | 12:27 PM
ITRacer121's Avatar
I have a set for sale if anyone is interested?
&lt;---got a more agressive cam and had to go to larger injectors
Old Nov 8, 2005 | 10:47 PM
victorpapa's Avatar
Default Re: (ITRacer121)
Eva & George: I decided to run 60 psi ( it is only a test) for my set up and because the sparks seems to me to be very white in colour, after the swap with the ecu jdm conversion
Old Nov 11, 2005 | 04:58 AM
victorpapa's Avatar
Default Re: (victorpapa)
How do you measure the fuel pressure? Hose disconnected and pinched I suppose.
So in order to run 290cc/min i have to lower the pressure at 43-45 psi?
renegadez7o7
Jun 28, 2006 05:10 PM
CRXLST
Apr 1, 2005 08:09 PM
impound
Feb 16, 2005 06:12 PM
ptsaurus
Dec 2, 2003 08:33 PM
fredtoast
Apr 25, 2003 07:16 AM
