What size BOLT is this?..dimesions?
Old Nov 7, 2005 | 10:27 AM
user 72830283's Avatar
Default What size BOLT is this?..dimesions?
well i bought one of those open cats or whatever from ebay and they that O2 whole on the bottom, its got a bolt through it...does anyone know the dimesions of this bolts? i know the head is big probably like 22mm or something...any help is appreciated ..thanks..
reason why i asked is cuz it must've loosened up and it fell out ..and now i have a whole there...and i need to seal it up..
THIS whole is what i'm tlaking about:
Old Nov 7, 2005 | 10:31 AM
Jonathan_ED3's Avatar
I'm not understanding what you need to do.
You need to find a bolt that has the same thread pitch as some other bolt that was in this location?
You need to replace the bolt? Is that it?
Grab a thread gauge and just check the pitch, then go get yourself a bolt (that matches the threads) and bolt it back in.
Old Nov 7, 2005 | 10:53 AM
APEX CRX's Avatar
Default Re: What size BOLT is this?..dimesions? (pr3d)
so the cat had a bolt in a O2 hole that has fallen out? The bolt is a pain to find. I would go to a mechanic or muffler shop and ask for a bad O2 sensor that they were going to throw away and use that to plug up the unused bung.
Old Nov 7, 2005 | 11:18 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
I come up with 18mm X 1.5mm pitch...
Edit:
You can probably find an old spark plug that size for the time being...
Modified by 88DXCRX at 2:29 PM 11/7/2005
Old Nov 7, 2005 | 11:35 AM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: What size BOLT is this?..dimesions? (88DXCRX)
put some high temp thread locker before u put it back in. Cuz u know how when things heat up, they expand and thats probably how the original bolt came out
Old Nov 7, 2005 | 01:35 PM
EJ1 wilcox's Avatar
Default Re: What size BOLT is this?..dimesions? (rukawa1one)
You can get an O2 sensor plug.
Check eBay for one. You can find them at a lot of different places. I had a plug in my downpipe that I would use when I wasn't using my wideband.
Either that, or like already suggested, pick up a broken O2 sensor and throw it in there.
poolpool8
Apr 1, 2017 09:12 PM
Ragecloak
Feb 25, 2005 07:54 AM
thrty8street
34
Jun 28, 2004 07:06 AM
J_Edwards
Jun 7, 2004 06:42 PM
GroundZer0
Mar 12, 2004 07:06 AM
