17x7 on EF
Old Nov 7, 2005 | 08:49 AM
G60's Avatar
G60
Default 17x7 on EF
Got a set of Enkei wheels. They are 17x7 et 42, running 215-40 tires. Will these fit without rubbing? I'd check but the nuts don't fit and I need small ones. TIA.
edit: oh yeah, at stock height that is.
Old Nov 7, 2005 | 08:58 AM
CRX Toad's Avatar
Default Re: 17x7 on EF (G60)
They will fit you may have some rubbing issues at full lock. I will warn you that your ride will turn to crap, it will be rough and it will find every rut in the road.
Old Nov 7, 2005 | 09:56 AM
APEX CRX's Avatar
Default Re: 17x7 on EF (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">They will fit you may have some rubbing issues at full lock. I will warn you that your ride will turn to crap, it will be rough and it will find every rut in the road. </TD></TR></TABLE>
I agree, 17's are just too much on a CRX
Old Nov 7, 2005 | 11:09 AM
barely4dr's Avatar
Default Re: 17x7 on EF (APEX CRX)
I have 17's on my sedan and I absolutely HATE them! I feel every bump, rut, nook, and cranny the road throws my way. I am desperately saving to get some 15's.
Old Nov 7, 2005 | 11:24 AM
CRX Toad's Avatar
Default Re: 17x7 on EF (barely4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by barely4dr &raquo;</TD></TR><TR><TD CLASS="quote">I have 17's on my sedan and I absolutely HATE them! I feel every bump, rut, nook, and cranny the road throws my way. I am desperately saving to get some 15's.</TD></TR></TABLE>
WISE BEFORE YOUR TIME I felt the same way out the 17's I had on my wife's 96 Coupe... 17's = junk.
Old Nov 7, 2005 | 11:34 AM
PaImportTuner's Avatar
my 205/40/17s ride good. so does my friend's 18s. i dont know what brand tires you all are using for 17s. oh yeh no rubbing issues on mine i could probably go 45 series..
Old Nov 7, 2005 | 12:14 PM
g-ride-si's Avatar
my 204/40/17s SUCKED thats why they are gone now. they tend to ruin suspension parts too. also make it handle worse. I had falken azenis on them. they put a lot of wear on your car because of the low pro/stiff sidewalls. 16s arent too bad but look for 15s if you want a nice ride.
Old Nov 7, 2005 | 03:45 PM
TheRex's Avatar
Default Re: (g-ride-si)
I got the 17x7 Tenzo-R Shu 10 with Nitto Neo Gen 205/40/17 on it and it rides pretty rough rubs with i turn lock to lock and i got it lowered to where theres almost to space between the tires and fenders
Old Nov 7, 2005 | 04:13 PM
EG8R's Avatar
Default Re: (TheRex)
I found anything other than stock size follows ruts. My Azenis were terrible for it...
Old Nov 7, 2005 | 07:48 PM
mahatma's Avatar
Default Re: (skelly ed666)
They'll probably rub some due to the 215 width.
As for the driving aspects, my old CRX never handled better than when it had 205/40/17's. Sure the ride was rough, and it was slower to accelerate, but it gripped like a monkey.
Old Nov 8, 2005 | 05:24 PM
TheRex's Avatar
Default Re: (mahatma)
gripped like a monkey. nice
Old Nov 8, 2005 | 06:12 PM
CRX_1.8T's Avatar
I have Wilwood 13 inch brakes so I am stuck with 17's. It grips like no other, but a lot of it ddepends on the tire too. I have Falken rubber bands on mine and it is a good combo.
Old Nov 8, 2005 | 06:13 PM
CRXBart's Avatar
My old 17's. I gotta say my 205-50-15s grip better and rub less. They only rubbed on me when I hit a bump while turning and then fubared the front fender. It doesn't help that it was supperdumped. I have rubbing at full lock with both setups though, so just don't go full lock. It could have something to do with the preload setting on my Z-10 kit though, cause it only rubs the front part of the unibody.
Old Nov 9, 2005 | 05:19 AM
G60's Avatar
G60
Default Re: (CRXBart)
would it be any different between a civic hatch and a crx, or are the wheel wells and everything pretty much the same?
Old Nov 9, 2005 | 05:32 AM
CRX Toad's Avatar
Default Re: (G60)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G60 &raquo;</TD></TR><TR><TD CLASS="quote">would it be any different between a civic hatch and a crx, or are the wheel wells and everything pretty much the same?</TD></TR></TABLE>
Pretty much the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote"> It could have something to do with the preload setting on my Z-10 kit though, cause it only rubs the front part of the unibody.</TD></TR></TABLE> Mine rubs the same so it might not be the Z-10 kit. Or my car is just screwy.
Old Nov 9, 2005 | 06:01 AM
Default Re: (CRX Toad)
like i posted above and also it all depends on offset of rim, tire grip/brand and how low you are. i have front and rear camber kits and da front knuckles up front and when lowered on 17s my car never rubs and i had falkens up front and kuhmos in back and switched them. falkens are less noise and more grip.
Old Nov 9, 2005 | 07:57 AM
crxsi8's Avatar
17's is like skiing on top of ice!
Old Nov 9, 2005 | 09:47 AM
NACvicSi's Avatar
Default Re: (crxsi8)
I have 17"s on my 91 SI HB and have no rubbing at all. I run 204/45/R17s. I like them for daily driving, track tires are deff 15"s though.
Old Nov 15, 2005 | 09:45 PM
tapuout's Avatar
So I guess 18'r out of the question? hmmm...guess i must sell my tsw trophy's...oh well
Old Nov 16, 2005 | 10:07 AM
NACvicSi's Avatar
Default Re: (graciebjj)
guess so...
Old Nov 18, 2005 | 04:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graciebjj &raquo;</TD></TR><TR><TD CLASS="quote">So I guess 18'r out of the question? hmmm...guess i must sell my tsw trophy's...oh well</TD></TR></TABLE>
18s fit.
Old Nov 18, 2005 | 04:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi8 &raquo;</TD></TR><TR><TD CLASS="quote">17's is like skiing on top of ice!</TD></TR></TABLE>
if you had new camber unmolested tires and camber kit with good camber your car would handle/feel 10x better and feel safer then 195/60/14s.
never had problems with my 17s and my friend doesnt have problems with his 18s. my 17s with tires weigh less then my 14" rims with tires. i feel my car <u>launches</u> better with 17s but doesnt grip as good in 1st but 2nd++ gears grip. my 14s in 1st 2nd break loose and 3rd slight chirp.
Old Nov 18, 2005 | 05:04 AM
Tbindas's Avatar
i had 17s on my hatch when it was stock... they fit fine w/out rubbing but they were 205 width. The ride sucked and i traded them for a set of OZ wheels and a set of SI wheels (i won out in that trade) sold the OZ wheels for more than i paid for the 17s and now i am rocking OEM 2000 si wheels... 17s might look nice but if you intend on putting down any power to the wheels you will hate them. btw... rubber is expensive
Old Nov 18, 2005 | 05:09 AM
Tbindas's Avatar
Default Re: (Tbindas)
before
after ;-)
-it may be hard to tell the difference but thats why they call it a sleeper ;-)
Old Nov 18, 2005 | 05:12 AM
zccr-xsi's Avatar
they look good on that red crx i guess it look good on show car.in my opinon stick with 14s or 15s.17s have to much rotating mass.
