3rd gen itr suspension on an eg civic
Old Nov 7, 2005 | 07:12 AM
white93civicex's Avatar
Default 3rd gen itr suspension on an eg civic
Hi,
I was wondering if it is possible to bolt on the suspension from a 3rd gen itr onto an eg civic. I would have the shocks, springs, front and rear sway bars, rear tie bar, and the front and rear LCA's. If anyone has done this, or knows if it can be done I'd like to hear from you.
thanks,
Chris
Old Nov 7, 2005 | 08:23 PM
RaceCarRyne's Avatar
Default Re: 3rd gen itr suspension on an eg civic (white93civicex)
it will all bolt up
Old Nov 7, 2005 | 08:31 PM
hatchi's Avatar
plug n play
Old Nov 8, 2005 | 08:39 AM
Default Re: 3rd gen itr suspension on an eg civic (hatchi)
Thanks for the response,
I was wondering how difficult this swap was.
I was on another civic forum, and I got a couple of people saying that either it's impossible to do this swap, it can be done but the sway bars won't work, it can be done but the rear LCA's will increase the negative camber and rear toe-in (but this guy had only done the swap on an ef civic).
Has anyone ever done this, and even if it is direct bolt-on, will it change the geometry of my current suspension for the worse
Old Nov 8, 2005 | 08:41 AM
JDM-EJ1's Avatar
It's actually really simple. I did a write-up on shock removal/install. This should help you get started.
https://honda-tech.com/zerothread?id=1427142
bobby_da6
Sep 10, 2008 05:23 PM
white93civicex
Nov 6, 2005 09:45 PM
jay007
Apr 23, 2004 08:07 AM
743power
Feb 12, 2003 06:05 PM
