hb no start.
Old Nov 7, 2005 | 04:36 AM
s10cky's Avatar
Default hb no start.
hey guys,
my car wont start. heres the lo-down. i was trying to hook up a cd player from scratch, getting my power, ignition, ground and such. i cut a wire under the dash near the fuse box that i tested and found to be constant. when i cut it i tried turning the car on it did. finally i found an on/off or ignition wire, tapped into it. when i tried turning the cd player it didnt. i was like ok...so i tested the wires againg and they werent showing up to be hot. checked some fuses and one was blown, replaced it and others started blowing. now none are blown, ive disconected all the wires that i tapped into and redid them, the car wont start. i found that its not getting spark. but no blown fuses. maybe a relay???
,matt
Old Nov 7, 2005 | 05:28 AM
s10cky's Avatar
i need help quick, maybe a wiring scematic.
Old Nov 7, 2005 | 05:31 AM
YoshiLegend's Avatar
Default Re: hb no start. (s10cky)
if your not getting any spark check your power distribution under the hood and make sure all of your fuses are good. also you might want to pull of your distributor cap might have a bad ignition coil i just burned up one in my 91 crx. if you get spark and it still doesnt start the only thing it could be is a fuel problem.
Old Nov 7, 2005 | 05:35 AM
s10cky's Avatar
ok, yea I already checked my power distribution block yesterday, all good.
i think the distibutor might be bad. ill check today
Old Nov 7, 2005 | 06:00 AM
s10cky's Avatar
well it looks ok when i took the cap off, how do i know its a bad coil?
Old Nov 7, 2005 | 06:44 AM
iTe4LIFe's Avatar
how about your fuses under your hood? did you check those? does your starter crank the engine when you turn the key? are you getting proper power through your car without even trying to start it?
Old Nov 7, 2005 | 06:55 AM
s10cky's Avatar
yes, its cranking. checked the fuses under the hood. the one thing that it doesnt do now is the little battery light doesnt come on in the cluster.
Old Nov 7, 2005 | 10:27 AM
vtecn8ive's Avatar
Default Re: (s10cky)
I'm guessing its the black/white wire you messed up on. This goes from ignition to starter switch.
ouch man if you don't know what you are doing you shouldn't be messing with electricity. Why would CUT wires near the fuse box??
Old Nov 7, 2005 | 12:01 PM
s10cky's Avatar
lol, i know wtf im doing. that wire is intact and I know what it is. if that wire wasnt hooked up then it wouldnt crank over. i changed the coil and still no fix. im checking to see if the fuel pump is getting power now.
Old Nov 7, 2005 | 12:05 PM
vtecn8ive's Avatar
oops duh forgot you said it was cranking .
Old Nov 7, 2005 | 12:15 PM
s10cky's Avatar
its ok. i just checked the fuel sending unit and no wires are getting power. are they supposed to when the ignition is on without cranking, i would think so.
I think theres a bad relay in the fuel wiring system, what do you guys think??
Old Nov 7, 2005 | 12:18 PM
vtecn8ive's Avatar
I was going to also say it may be the main relay. blowing all those fuses could have messed up the main relay.
Old Nov 7, 2005 | 12:22 PM
s10cky's Avatar
is the main relay on the fuse box? the one next to all the fuses? thanks for the help so far.
Old Nov 7, 2005 | 04:37 PM
s10cky's Avatar
bump
Old Nov 7, 2005 | 04:45 PM
vtecn8ive's Avatar
oops got off work didn't realize you replied .
Main relay is behind your coin holder on the left side of the steering wheel. You actually need to take the coin holder out and then you can see what I am talking about it. it'll say main relay on it. kinda big.
-Shane
Old Nov 7, 2005 | 05:26 PM
Craigp23usa's Avatar
when you turn the key to ignition on the fuel pump should turn on for two seconds to build pressure. this is what main relay cntrl. that and other things. listen for the pump after its been sitting to loose a little pressure so the pump has to turn on.
Old Nov 7, 2005 | 06:24 PM
s10cky's Avatar
well i checked that too earlier to today. its not getting power, and I dont think the distributor is either. what could it be??
Old Nov 7, 2005 | 06:33 PM
s10cky's Avatar
ooops, didnt see ur post shane. wow, that relay is huge, i have a parts hb about 5 miles down the road and i jacked every relay he had and replaced it, but never saw that darn thing. ive done everything but that. i really hope this works, thanks.
Old Nov 8, 2005 | 06:09 AM
Let us know if it fixed the problm.
Old Nov 8, 2005 | 10:43 AM
s10cky's Avatar
i will, going to check it out in about an hour.
Old Nov 8, 2005 | 12:29 PM
s10cky's Avatar
nope, didnt work, expletive this car. anyone want a hatch with some electricity problems.
Old Nov 8, 2005 | 01:01 PM
No fuel...No ignition. Sounds closer and closer to a computer. I love problems like these. If it where me. i would retrace all of my steps and really think about what it was doing right before it stoped running. Any problems you might have had that could have escelated. etc.
Old Nov 8, 2005 | 01:14 PM
s10cky's Avatar
yea, ive been thinking all day lol. the only thing I can think of before it stopped running was a wierd idle every once in a while, no turn signals, i think the switch is bad, and the cluster warning lights never worked, like seat belt, etc. but the actual illumination has always worked. and....uhhh. left rear brake light wouldnt work when the lights were on.
Old Nov 8, 2005 | 01:18 PM
s10cky's Avatar
anyone else, thanks for the help so far guys.
Old Nov 8, 2005 | 02:08 PM
s10cky's Avatar
that little red light on the ecu doesnt come on when the ignition comes on. is it supposed too?
