TONS of parts, Civic, CRX, Integra, turbo, OEM, Buddy Club exhaust, CLEARING GARAGE!!!
Clearing out the basement and have all this stuff for sale, also have some other little misc. crap so ask and I might have. All prices are OBO.
92-95 Civic
-Buddy Club Spec II exhaust, like new, used 400 miles $325
-Gauge cluster bezel, small crack, can't notice when installed, has clock delete $10
-A pillar trim pieces, driver side has gauge pod installed $20/both
-Hatchback OEM sideskirts, painted Fresco Green $40
-Door molding, no broken clips $10
-Rear hatch glass $25
-Hatch rear panel gray with light covers $10
-Rear glass hatch struts $15
-Center dash vent, black, $5
-Shift boot, black leather $5
-Wiper assembly, linkage and all $20
-2/3dr driver headlight $15
-Rear cargo cover, blue, no rips or tears, $35
-Steering wheel with airbag, blue $40
-Blower motor for heat/vent/AC $15
-Hatchback headliner $15
88-91 CRX
-OEM sideskirts $20
-Rear hatch trim pieces, black $5
-E-Brake console, black $10
-Headlights, small BB gun hole in pass side, no leaks, $20/pair
-90-91 B pillar door trim $5
-OEM clock $5
-OEM rear speaker brackets, 2 pair, $10/pair
-88-89 center taillight $15
94-01 Integra
OEM LS exhaust, like new, has Honda stamping and OEM chrome tip $110
OEM power mirrors, vogue silver, like new $25/each $40/pair
B Series
-OEM cam gears $10
-OEM B16/GSR oil cooler $10
-Greddy B18C/B16B timing belt, used 200 miles, $60
-OEM oil squirters $20
-Flywheel cover $10
-B16A lower OEM header $10
-Polised OEM fuel rail, modified to use AN line and fittings $25
-(3) flywheels, all good $15/each
-(2) starters $30
-JDM ITR header heat shield $25
-96+ B20/LS valve cover, could use a repaint $20
-Altenator brackets upper and lower $5/each
-GSR B18C crank, small knick on rod journal, can be fixed $25
-Windage tray, non-GSR $10
D series
-NEW OEM Honda exhaust manifold gasket $10
-Z6 throttle body with TPS and MAP $20
-Polished Z6 fuel rail $15
Turbo
-Box 'O T3 turbo parts, 3 compressor housing (2) 45 trim (1) 50 trim, all include the wheels as well, 2 center sections, 1 T3 exhaust housing. Everything is in very good condition, enough parts to make 1 good turbo and have left overs, perfect for D series. $125 for all
-SAAB hard pipes and reinforced couplers. About 8 couplers and 4 LONG hard pipes. Complete charge system taken from 2 cars. $50 for all
-DSM BOV, brushed aluminum $20
MISC.
-B/D tranny mounts for 92-95/94-01, one OEM one filled polyurethane $5 for OEM $15 for filled
-Walbro 255lph fuel pump, used 700 miles $70
-Autometer Phantom volt gauge $20
-OEM Honda resistor box with plug $10
92-95 Civic
88-91 CRX
-OEM sideskirts $20
-OEM clock $5
94-01 Integra
B Series
-OEM cam gears $10
-Flywheel cover $10
-(2) starters $30
D series
Turbo
MISC.
Luder94
Aug 2, 2006 02:56 PM
