B20 parts question?
Old Nov 6, 2005 | 09:09 PM
doh240's Avatar
Default B20 parts question?
got a question for you folks,
couldn't find the answer - yeah i know, my searching skills need to be sharpened but this should be a quickie...
got a 96/97 rs with couple of bolt ons, I/H/E,
if I were to put in a B20 (non vtec conversion), would everything still fit, like the I/H/E?
thanx in advanced
Old Nov 6, 2005 | 09:25 PM
Backk InTheDA's Avatar
I hate everything
Default Re: B20 parts question? (doh240)
A b series is a b series.
Old Nov 7, 2005 | 09:14 AM
doh240's Avatar
Default Re: B20 parts question? (BuilttB18C5)
so...
that means the old I/H/E from the teg will work with the crv motor?
Old Nov 8, 2005 | 01:24 PM
silver_flash99's Avatar
you are correct every thing will fit
Old Nov 8, 2005 | 01:27 PM
projectTeG's Avatar
yes you might have to change your intake manifold from the b20 one to the rs one, but they are basically the same engine so everything will fit.
Old Nov 8, 2005 | 01:46 PM
huoyuanjia's Avatar
All should work block and head, head, intake, exhaust; however if it was a GSR with dual im. Then the intake may be different.
Old Nov 8, 2005 | 01:49 PM
mjc1055's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">yes you might have to change your intake manifold from the b20 one to the rs one, but they are basically the same engine so everything will fit.</TD></TR></TABLE>
b20 heads are exactly identical to b18b heads, so there's no reason why the intake manifold shouldn't work.
Yes, all of your bolt-ons will fit.
Old Nov 8, 2005 | 01:54 PM
projectTeG's Avatar
Default Re: (mjc1055)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjc1055 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, all of your bolt-ons will fit.</TD></TR></TABLE>
mostly they are unless its the p8r head. i didnt say that the heads were different....the intake manifolds are different on some b20s, they are taller or like a box.....for example B20: http://www.hmotorsonline.com/s...30025 LS: http://www.hmotorsonline.com/s...30023
do those manifolds look the same to you?
Old Nov 8, 2005 | 01:57 PM
mjc1055's Avatar
haha. wtf is that?! At first I thought it was some kind of crazy shield..
Alright, how's this then. As long as you don't have some freak of an intake manifold, it should work
Old Nov 8, 2005 | 01:58 PM
doh240's Avatar
cool,
THANKS y'all!!
SLPN H
Jul 25, 2011 09:23 PM
crxhondata
26
Aug 1, 2008 09:47 AM
civic center
Nov 19, 2004 09:59 PM
CarbonCreations
Sep 19, 2003 02:24 AM
dbman96
May 9, 2002 02:35 PM
