when it says......? would fit on b16 from 92-00 would it fit a 89-91 b16a1?
Old Nov 6, 2005 | 08:53 PM
89civich22's Avatar
Default when it says......? would fit on b16 from 92-00 would it fit a 89-91 b16a1?
because i want to get parts for my b16a1 for my 89 civic si i want to get cams a turbo kit low.....pistons pulleys injecters intake maifold a better thorttle body a stage 2 clutch a valve job but if i dont go turbo i want to get header and intake so..... what would i have to look at to know if it would fit a b16a1 which is for the years 89-91 civics
Old Nov 6, 2005 | 09:01 PM
Mr_Si-R's Avatar
Default Re: when it says......? would fit on b16 from 92-00 would it fit a 89-91 b16a1? (89civich22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civich22 &raquo;</TD></TR><TR><TD CLASS="quote">because i want to get parts for my b16a1 for my 89 civic si i want to get cams a turbo kit low.....pistons pulleys injecters intake maifold a better thorttle body a stage 2 clutch a valve job but if i dont go turbo i want to get header and intake so..... what would i have to look at to know if it would fit a b16a1 which is for the years 89-91 civics </TD></TR></TABLE>
well that b16 from the 99-2000 is a b16a2 i belive, so i dont think that will work, but i cant tell you for sure
Old Nov 6, 2005 | 09:14 PM
crxnj's Avatar
Cams- As long as they're made for dohcvtec b-series motor,they'll work..
Turbokit- Some companies make kits for the 88-91 civic/crx with a b-series motor..Drag,revhard,turbonetics,etc..Or you can custom fab one yourself..Any b-series turbo manifold will work..
Pistons- All b-series pistons will work except b20,which has larger bores
Injectors- You'll need peak and hold
Intake manifold- All dohc vtec b-series will work..except gsr b18c/sir-g b18c
Clutch- Any b-series cable tranny
Intake- Aem makes a hybrid intake made for a 88-91 car with a b16a
Header-Hasport makes a header for the 88-91 car with a b-series motor with the 2 o2 bungs and has decent ground clearance..But any b-series manifold will bolt up to the head
http://www.toronto-lime.com/mu...r.wmv
Modified by Mr.speaker at 2:06 AM 11/8/2005
94lt1
Feb 25, 2007 12:17 AM
MindLess311
Honda Fit
12
May 1, 2006 09:14 PM
89civicb16a1
13
Apr 30, 2006 09:00 AM
EF_yo_89
Oct 26, 2004 02:10 PM
slammed_93_hatch
Nov 8, 2003 09:14 AM
