h22 swap in 91 accord
h22 swap soon!!! Question is: will the body harness plug straight into the engine harness without and splicing? Also, will everything thing electronic wise still function the same as before when the p13 ECU goes in?
P.S. Please let me know of any difficult/unusual problems that any of you faced when doing this swap
thanks for positive input!
an H22 swap in an accord uses the accord wiring harness( u must splice in the vtec wire and 3 other wires (drawing a blank right now) into your ECU), use accord axles, use the accord fuel rail with the h22 injectors, if u use an H series tranny u must tap the tranny in the empty hole closer to the front of the tranny and use accord motor mounts, and make sure all your sensors are in good shape, if available use a chipped P28 or P72 ECU. Make sure to get the car tuned ASAP for better performance. Good luck with your swap.
