More clutch problems....Need help
k, couple nights ago my clutch was stuck to the floor and i didnt know the problem, so i looked for the problem...
the only thing i saw was that the hardline that is connected to the Master cylinder? [the one that is mounter on the tranny] was leaking at the nut closest to the cylinder
anyways...i got a new hardline, leak problem solved, i filled up the resovoir, Bled the line until there was nothing but brake fluid in it....BUT THERE IS STILL NO CLUTCH PRESSURE?!?!
the clutch is still stuck to the ground, and even when it's down all the way i cant get it into gear
and even when i push that Arm/pump that is connected TO the cylinder [asuming that when this is down it should go into gear?] it still wont go into gear
WTF could be the problem??? i cant see a leak anywhere on the line, nor on the inside of the car but the clutch continues to stay on the ground ie. no pressure, and even when it is down it wont go into gear?
could be the clutch master or slave cylinder... or could be a bent release fork...also make sure that the slave is into the sphere thing on the release fork..if it's not pushing on the fork there will be no pressure.. pressure comes from the fork pushing on the pressure plate
phatsindabuildin
Mar 25, 2008 06:57 PM
