p28 on obd0 b16a crx
Old Nov 6, 2005 | 05:05 PM
irishone's Avatar
Default p28 on obd0 b16a crx
unless im completely over looking something.... If a 89 crx has an obd0 b16 swap i can run a jumper harness and a chipped p28 with uber. or do i have to swap change the distributor plugs and splice the resistor box wires together?TIA!
Old Nov 6, 2005 | 05:18 PM
eda6's Avatar
Default Re: p28 on obd0 b16a crx (irishone)
you can get the distributor and ecu conversion harnesses and run the chipped p28.
or you can change the dizzy plugs if you don't want to buy the distributor jumper.
You can use the preobd injectors with the p28.
If you're using peak and hold injectors don't touch the resistor box. If you're using saturated injectors splice the resistor box wires together.
Old Nov 6, 2005 | 05:46 PM
CoreyR's Avatar
Default Re: p28 on obd0 b16a crx (eda6)
youll need a 4 wire o2 sensor also. you cant use the OBD0 distributor, gotta get a OBD1.
Old Nov 6, 2005 | 06:23 PM
Rywire's Avatar
Default Re: p28 on obd0 b16a crx (CoreyR)
both are correct
Old Nov 11, 2005 | 01:36 PM
irishone's Avatar
Default Re: p28 on obd0 b16a crx (droppedcrxsi)
thanks guys....i'll just swap the plugs since i have the obd1 distributor plugs from a parts car i had. also have a bunch of four wire 02's laying around. thanks again.
red civic standard
Jul 31, 2013 03:05 PM
siR in progress
25
Aug 3, 2011 03:08 PM
joey6098
Jul 29, 2011 02:20 PM
krazeemidget
Nov 11, 2003 10:05 AM
100whplusperliter
30
Oct 28, 2003 06:27 PM
